E66: Unable to send message
3 replies · 8,799 views · Started 03 May 2009
Hi all,
I am having problem sending out SMS message.
I have tried the following:
- reset with *#7780#
- reset with *#7379#
- installed the most up-to-date software
- verified that all the settings and Service Center are correct
the phone is being used on T-Mobile USA network, we can send/receive MMS, and only receive SMS.
If anyone know a work around, please share it me.
Appreciate all your time.
Tommy
What about visiting a NSP - Nokia Service Point ? Or check with your provider . BTW *#7379# Reset I don't know about . Did you mean *#7370# , Hard Reset ?
😊 Regards jApi
I'm just experiencing exactly the same problem with my E90, and after visiting both my (very competant) 02 store and a Nokia repaire specialist, neither can find out what's wrong and I'm now set to send my phone back to Nokia for repair on Monday. But before I do; did you manage to fix the problem, and if so how?
Cheers,
Aidan
i had a funny situation; sms's and a couple of mms's i had sent to my daughter over a period of some hours arrived the next day all in a bunch. that's gotta be t-mo not the phone, yea??
