Now whats wrong with my 7650?
It has started to throw those "System error" messages..
If i press camera it gives me that message. and same thing if i press messages...When i reboot the phone,after the Nokia logo it gives me 3 error messages... Virus 😮 ?
And, What is flashing?I have 1 flashing prog...
7650-whats wrong?
If I were you, I'd do a soft reset, and (assuming you have a backup via pc suite), reinstall all your data/apps/settings over the infrared.
If that doesn't work, either a hard reset or a visit to the NSC.
Paul
If you had previously installed wildskinz and removed them later, reinstall them, and try to reboot the phone. In order to remove them t have to disable them first, reboot,and them uninstall them. Also don't compress wildskinz with stacker or space doubler cause after a reboot u will see those error messages...If u have installed and compressed wildskinz uncompress them and reboot...
I reseted the phone..Thank god i made the backup 😃
Everything is fine again.Exept my great high scores at GemJam and Caveman etc. 😞
Hmm..I had that wild skinz, but i didn't compress it..
When i removed it, the phone started to throw those errors..
seems like a very unstable app, Wildskins - if you read everyone's experiences on this forum, you may think you're better off without it
Paul
Never tried it myself, I had enough problems with Trigenix!!!
I try not to install software before version 1.1 at least!
As i said, wildskinz need to be disabled before uninstalling them. The phone tries to run the system files from wildskinz but it can't find them. The same thing happens when the app is compressed. It cannot load them. I had the same errors but after reinstalling it, the errors disappeared.
HI!...
hehe!.. Wildskinz... nice app.. but i removed a long time ago...
simply i don't care about skins anymore... all work faster without skins... and WildSkinz is not compatible with most of the others important apps...
BTW! Trigenix is not an skin app by now ... look more like a simply INDEX INTRO to access the apps... but not skin for all the system places, menus and apps.
anyway... someday someone will do the right skin program for this...
cya! 😃
I agree AEFOX, until a good skin comes along which doesn't destabilise the OS, I can wait, with a few jpgs to make it look good.
The 7650 is also a phone 😃 we need to minimise severe crashes and resets....
paul
no thank's sir no skin for me today *LOL*
