Mrouter and PCSuite Nokia 7650
105 replies · 18,963 views · Started 03 March 2003
Hi All
Have read all the post but canot get any ports other than COM1/2 and IR in the Mrouter window. PCsuite dated Feb 03, W2K SP3, and 3com Blue tooth. Have tried the installs/reinstalls also disabled modem on COM1 also uninstalled Norton Firewall. No difference. Have I missed somthing? I can send files to and from phone using 3com Connection manager and use the Modem. Interestingly besides the Mrouter issue when I try to open PC suite it tells me to connect phone and Press "OK" but nothing happens the only thing I can do is close the program. All ports showning in Device manager.
Thansk A very frustrated Nokia user!!!!
Hi there
Problrm is the mRouter in the new PCSuite (1.2). Try to install old version ( 1.1) then save mRouter subdirectiry ( Intuwave ) someware.
Install again new version of PCSuite (1.2). Overwrite Intuwave subdirectory with the old one. Now mRouter should see all available ports. Hope it helps
Thanks for the suggestion but with that version of Mrouter no ports at all! This is the problem I had with the earlier version. It seems perhaps Mrouter is not picking up the ports on the install routine from the registry ?
Tony
You need to uninstall PC Suite and 3com software
Then follow instructions in this link
http://www.ocworkbench.com/2002/nokia/7650review/p4.htm
I had same problem. This link solved my problem for 98SE and 3com USB. I use version 1.1 of PCsuite though. Have heard that MRouter in 1.2 is buggy.
Doc
Thanks had seen that but I cant get any ports listed in Mrouter except COM1/2 and IR which is not even on the PC. Mrouter shows the ports missing if I disable them so it sees the hard ports but not the serial ones which in my case are on COM4/COM6 in Device manager
Tony
The fact that you can use 3com connection manager software shows that bluetooth and usb is working. Problem must be with Mrouter?
Do you have sdk installed with PCsuite?
I'm sorry I cant help more. I'm not too familiar with Win2k or PC Suite 1.2.
Doc
No I have not been installing the SDK option does this have any effect ? Yes I agree its a Mrouter issue or PcSuite as the other "Funny" is that I cant get passed the inital box that prompts me to connect it only allows me to close the PcSuite.
Tony
SDK is for connecting via cable to other phones, so not needed. Can cause hassles if loaded though
PCSuite won't startup for the first time unless Connected via Mrouter
What firmware is your phone, although this should not be an issue?
You do have Bluecom software loaded before installing PC Suite?
That was were I went wrong.
Hi Doc
Yes have Blutooth loaded during install and phone flashed to ver 4.39. Ithink this is a windows 2K issue or somthing I have on my PC that is causing the problem. Can you tell me if you disable the ports in Mrouter will PCsuite still open as mine wont. I have been assuming this is because there are no ports but if it still opens it suggests other issues. I could partition a part of the drive and install w98se but it seems a long way about.
Tony
PCSuite won't open for the first time if there is no Serial port.
I'm sure it's not W2000. I've seen many people using it with 2000. Even XP seems to be working now.
It could be something on your PC. I also have Norton Firewall though. No Problems with that.
When you open 3com Bluetooth manager and go to com ports does it list DUN, Serial, Lan and Fax clients with applicable Com ports?
Doc
yes it does and I can use the Modem (the 3com one) I have all showing in device manager (DUN,FAX,LAN and Serial Clients and a Serial Host).
Just that nothing comes up in Mrouter.
Do you know what the registry entries look like for Mrouter ? I could compare them
Tony
Sorry no idea what registry entries look like.
Have you tried what kreso suggested. I've heard it elsewhere that mrouter in v1.2 doesn't work but 1.1 does if you copy it over 1.2 files
Doc
Yes tried that but then I got NO ports! I am suspicious it may be a W2K thing with SP3 perhaps someone else has had a prtoblem with this set up
Tony 8)
Hi
I have using WinXP now for some time. Before I used W2K with SP3. I installed PCSuite v1.1 and 3Com BT. After some problems I get it working most of the time. Because of disk crash I installed WinXp. In the same time Nokia release PCSuite 1.2 so I deside to giv it the try. Result NO GO. PCsuite installed first then 3Com BT SW- NO GO. I also try different aproach which is 3Com BT SW first PCSuite afterwards- NO GO. I all instances only COM1/2/IR available. After last attempt with no luck I cleand my system completly from PCSuite and 3Com BT SW( subdirectories and registry) and start from schratch. Here is how I done it.
1. Installed 3Com BT SW and drivers
2. Reboot
3. Installed PCSuite v 1.1
4. Reboot
5. Copy Intuwave subdirectory
6. uninstalled PCSuite v1.1
7. Reboot
8. Install PCSuite v1.2
9. Rewrite Intuwave subdirectory with old(1.1)
10. Reboot
11. Start 3Com BT Manager and check for the COM ports
12. Start mRouter and you should see all available COM ports
13. Check COM ports for the BT connection (3 and 4 in my case )
14. mRouter may complain that port is in use but soon it will connect
Hope this helps
regards
g3uiss, have you had any luck yet?
i have almost the same problem, running WIN2K and i assume PC Suite 1.2.
Kreso, will try your method - i know my bluetooth is working as i can connect and see Nokia7650 on my PC and send info requests from explorer, its just MRouter which is playing up!
Matw
No I have tried the use of the older version of Mrouter but all I have is V1.0 not 1.1 but using the Mrouter folder "Intuwave" etc I get no ports at all!
If you have exactly the same problems there must be somthing in common. I can use the Bluetooth software to transfer files and access through the modem.
Tony
yeah this sounds exactly like my problem
i will try my best to find a fix, and if i do, will PM you with what i've done as i would guess it is the same thing!
No Luck did everything suggested. Need someone else to let me see what regisrty entries look like on W2K so can compare I think Mrouter does not see ports on install
Tony
hi there.
I have the same problem with the new version of PCSuite (1.2).
What I did was to overwrite the new directory of mrouter on the installer of PCSuite 1.2 with the old one from PCSuite 1.1
This solution is at the installer level and worked for me.
Charral
I tried that a least with V1.0 as I did not have V1.1. When I did that I got no ports at all. Do you know if the "Intuwave" files were updated between V1.0 and 1.1 if so perhaps could you "Zip" them and email me?
Tony
*****Solved*****
To all that responded thanks. The solution was similar to suggested but as follows. Install 3 Com and ensure works with phone ie connects. Install PCsuite 1.0 or 1.1 go to the Intuwave directory and copy the MrouterSerial.dll to a tempoary locatation. Uninstall PcSuite. Install PcSuite V1.2. Now the tricky bit. You need to stop the Mrouter/Connection Manager/Broadcast/econnect programs that the suite runs at startup by using cntrl/alt/del and end these progs or in W2k/XP stop in the services tab. Now overwrite the Mrouterserial.dll with the old version you stored and reboot and it all works!
Happy to claify if needed. The main issue is that the mrouterseril.dll will not copy if any of the PCSuite internal programs are running. hence the instructions. Good Luck...Tony
There is a 2k/XP app which replaces files currently in use by the O/S, if anyone needs, please PM me and ill mail it over
Eck
does anyone have Nokia PC Suite v1.1 - im pretty sure that i can get it working if i were to be able to get this software, but the Nokia site only seems to give you the latest version, 1.2, and that is whats on my CD.
Please PM me if you can help 😃 , ive looked hard for it elsewhere but thought it should be ok to post this request here as i have PC Suite and it is a free download that anyone can have.
Cheers
Matt
Matt
As you only need the Mrouterserial.dll I can email this to you ziped up its only 273K before compression. You can then install V1.2 and copy this over after the install taking note to stop the programs. Advise an email address
Tony
[quote="Anonymous"]*****Solved*****
Happy to claify if needed. The main issue is that the mrouterseril.dll will not copy if any of the PCSuite internal programs are running. hence the instructions. Good Luck...Tony[/quote]
Hi Tony
Glad you sorted it out.
I've taken PC Suite out of my Startup directory. I only load it when I need to make a backup. The rest of the time I use the 3com software without mrouter. That way you can send from phone to PC via BT
Hi Doc
Yes I have done the same. In fact when you run PcSuite it loads all the necessary programs so they dont really need to be in the startup directory. One wonders how less tecnical aware users would ever get this working!
Cheers
Tony
Guys,
could you please clarify something for me. The RS60 allows connection through IR and BT but it also mentions TCP/IP, what does that mean?
Am I wrong to believe that 7650 could be remotely controlled through Internet? Basically when we get a GPRS connection - for surfing f.i. - and attach to the network, there is an IP address assigned to the handset, although it's not visible as managed by network (GGSN), this IP adress could then serve as a connection and control point for the handset. Is RS60 designed for that?
Anyone knows?
