Any news with domi's FExplorer? any changes or updates?
Domi? pls post us a link if u got the 1.08 or higher ver... ive been just waiting for it ... 😃 Thanks man!
More Power!
More Power!
I use 1.07.
Where can I get v1.08?
It's one of the best programs for me.
You can go to the official site of FileExplorer (this site is kept up-to-date) :
www.gosymbian.com
There, you'll find a section '!! Next Version !!', there you'll find some screen shots of the version 1.08 (coming very soon, this week or next week).
thanks a lot !!!
Domi.
Great work Domi. I had just wanted to suggest what u had already incorporated in ur next version (1.08) ...ie.... variable (most importantly, Smaller) font options. Your's was pretty much a complete software..and it only needed some cosmetic changes (which u have done)
Excellent!!. Keep up the good work.
Regards
Thanks Domi, You just made a Great program even better 😃
Thanks to you for these encouragements 😃 😃 !!
And there are some other ideas reminding in my mind .... 😉
Domi.
hi domi..
i know i told you that before, but maybe someone else might find it usefull..
what i am missing is the possibility to send any file per bluetooth, sms or ir..
thats nice to share ringtones...
maybe you will find a way to manage it..
anybody else might find this usefull???
anyway great work domi...
Hi Tias,
Your 'send via ...' is missing in JUST YOUR version because you have a beta-test version with a .... bug !! that's the reason why the send menu doen't appeared any more (it's corrected since your travel in N-Y) !!!
Domi.
uii.. then i will look forward to the release of the new version 😊 😃
More power Domi!!
Dom, can u add a kelock function in ur new FE? 😃 so that i can get rid of this keylock-autoexec combo.... its so space consuming... 😃
Thanks Man!
Hey pidz111, what do you mean with a 'keylock' function ?? and in which way I can implement it ?? (for the best way to the end-user of course !)
Personnaly, I don't think it's necessary to have a such function since the phone (in fact its keyboard) can be closed and therefore there is no more access to the keyborad but I always try to make functions requested by the users !!!!
Domi.
could be nice 😊
eprofiles has the option that it autolooks the phone when you close the keypad.. and that works from the startup.. you dont have to activate it anytime you start your phone..
would be a nice feature to add, domi
But only if Fexplorer is running, you would need the app to start when the phone starts for this to work.
I use fexplore for filel management and One2Go for appointment & task management. One2Go is running constantly, so it is worth having the keypad lock app in it, fexplore is not.
Bob
Well domi, you are making a great work. I have an idea that it may be a little bit hard to implement. What about a plugin system in your fileexplorer wich will let the program do other things using plugins like using other fonts on your prog. Viewing gif, mp3, etc. That way the size of fe will kept small and if we need another feature we will just install the appropriate plugin. but that's only an idea. The program is perfect, if we have in mind its real purpose... Keep up the good work.......
thanks Domi!!!! keep it up bro!!! 😃 😃
MemphisX, concerning plugins, I'm thinking about this for a long time to make a sort of 'FileExplorer Pro' with many other features, if a user registers, he'll get other features as 'plugins' to maintain the size of FExplorer (normal version) at a low level of comsumption of disk ....
But FE is always small, now, in version 1.08 with an integrated viewer/editor, a customizable menu (for colors,...), ... I need only 55Kb ...
Domi.
Hi Domi, thanks for providing us with such a brilliant program!
One thing I would find VERY useful would be the ability to set any image as the wallpaper without having to first save the file to Images and then go to settings and so on..
Keep up the great work!
