try to search around the forum seems can't find any solution for above, everytime i open the flip, it play a very high pitch sound(like bird screaming). How to just disable this?not the silent mode, just this 1 while still have others sound alert enable.
how to disable the sound after open flip ?
i guess i'm very stupid, the sound actually is from the app Uptime, already disable it. Sorry for wasting your time if you happen to pop in or will the MODERATOR just help to delete this post.
thks
Thank you for posting this, not because I had the same problem but because I wanted to find a way of having a sound when you open the flip!
I have now downloaded the Star Trek (original series) communicator sound from here: http://www.stinsv.com/TOS/compa.htm#Sound and my P800 now sounds like Kirk's communicator, fulfilling my geeky dream I have had for twenty years! Sad, I know, but thanks. All I need now is getting UpTime to autorun and I will be even happier!
Cheers!
SpUd69
Well, why did you guys not try the search-button? There were at least two threads about this sound in the last month!
