Nim Video Clip on n9210.co.uk
10 replies · 3,826 views · Started 16 April 2002
Does anyone know who put the E.T video clip on the n9210.co.uk website, the quality is super, compared to every other clip which I have converted and all the others on the website, was this clip especially made for the 9210?
Any advice on how to covert clips to this superior quality would be very much appreciated!
Yeah, it is one clip which is just oooozing with quality, what a clip, and what a person who managed to do it!
I think its from Nokia, made specially for the 9210, because there is no clips which i've converted (about 200) which can match fro quality!
CHECK IT OUT!
I'll check when I get home to see if the poster left a name and e-mail. If they have I'll e-mail them for you and see if they want to share their secrets...
Does everyone use Multimedia Convertor Pro? Maybe thats how they got good results.
Regards
Ian
Well I've got the latest MMc converter from the Nokia website, and its just as crap as the old one1
The only so called improvements is a flashing arrow when it is converting!
There is no improvement in quality whatsoever when you convert the video clips!
I would really like to know how this clip was converted as the quality is simply sensational!
Yeah your right. I just download the clip. Unreal clarity though the frames are a bit jumpy. Intersting to know how they did it anyway.
Regards
Ian
I'm able to convert my clips to nim's with following specs
screensize 248*168
framerate 10fps
and a quality about twice as good as normal convertion (very nice).
I can increase the quality but the file size almost multiplies when I convert with the best possible quality.
I've uploaded a few clips to http//www.n9210.co.uk/
on 12/5/2002
