Casio Watch Camera
10 replies · 3,680 views · Started 16 April 2002
Just ordered my Casio colour watch camera from http//www.watch-heaven.com
WQV10D
The image software that comes with the Nokia allows you to transfer from the watch via Infra Red
I'm sure you'll get a discount if you mention my name "Rodney"
I'll upload some images when it arrives
I look forward to your review on this watch, so I too can buy one!
_________________
THE BEST IS YET TO COME<font size=-1>[ This Message was edited by 4u2nv on 2002-04-23 1633 ]</font>
Hmmmm... DigiCam on your wrist... what can i say??? It must be heaven!!! especially around the ladies fitting room... heheheh...
In that case, make sure it's not on your <I>busy</I> hand, or the pictures could be quite disturbing (if not a little blurred) User posted image
Cool.....Please do share your opinions. User posted image
The <A HREF="http//www.casio.com/watches/product.cfm?section=16&product=3972&display=21&cid=5116" TARGET="_blank"><B>Casio pics</B></A> the watch takes looks better than the crappy ones the bundled Matchbox camera from Concord does
(just look at my <A HREF="http//loonyworld.homepage.dk/moment/index.html" TARGET="_blank"><B>Pic of the moment</B></A> for some kind of comparison).Or at least it can�t be worse...So one might as well snap it to the wrist, If only it had an IR port..But i dosen�t ...DAMM...
But 80 pics ready to fire from the wrist..
That must be any photographers dream.
(I kow it�s one of mine...Go Go Gadget Camera) User posted image
You can beam the pictures from the WQv10 to the Nokia 9210 very quickly.
You select imaging/images via IR/Go and then set the Casio watch in send and it sends the current image in about 3 seconds....
Great fun, you can then email the results.....
The Casio works with the standard Nokia imaging application because it uses IR-TRAN-P which I believe is a "standard"
Cool
Rod
<B>COOL</B>
Now where did I get the info of NONE IR ...
Hmmm....Thanx for straighten it up...
/me rushes down to hear his dealer of avaliblety in Denmark User posted image
I just bought a WQV-3D watch in Swansea for �100. (which I thought was cheap as chips since it costs �239 on some web sites).
It has a mono screen but takes colour pictures and yes, it works out of the box with my 9210 without any problems!!!!! it will never replace my Samsung Digital Camera, but it is very neat.
Here's a comparison of a dull scene (weather not too good at the moment), the first is a scaled down photo taken from a Samsung 350SE and the rest are taken with the Casio Wrist Camera in different modes;
User posted image User posted image User posted image
The new model spoken of by the creator of this topic is likely to improve on the model I got......<font size=-1>[ This Message was edited by TANKERx on 2002-04-28 1703 ]</font>
