Hi group.
I am happily running my new 7650 at the moment after deciding to upgrade from my SE T68i. After a little concern about the size of the thing I have been very pleased with the phone (I got it for a bargain �35 with acessories on a one year contract from Phones4U... not bad I thought) and am using it extensively.
However I am running firmware version 3.16 at the moment and am keen to upgrade to the latest version, if only to help with some of the battery drain problems I am seeing (I am quite a heavy user as my phone is used for both work and pleasure).
Can anyone point me to a list of telephone number for a Nokia service centre in East Anglia? I would prefer somebody who will upgrade the phone while I wait around and not have the phone sent away.
Sorry if this is easy information to find - I have had a search on the internet but fialed to come up with much.
Thanks.
Go to the Club Nokia Web SIte. There is a section, when you login, about Phone support and NSCs alla over the UK. Just select your region and it will tell you where your local NSCs are.
Thanks for that sir!
I knew there must be a list somewhere on the Nokia site but I had completely missed this!!
ideal phones in chelmsford is nsc it took 30 mins to upgrade my phone and they have 4.39
Hi, There is a good service centre in Huntingdon called Communicade. They have version 4.39 as I had mine upgraded there a month ago.
Tel. 01480 431431, thay are situated behind the Mariott Hotel in the industrial estate. Very helpful, I just dissappeared for an hour and a half while they done the upgrade. Would have loved to see what went on in there labs but forgot my white coat 😊
you can also find the list on www.nokia.com -> phones (7650) -> support
can't say I've been to the clubnokia page, but this one tells you which operator the NSC works for, phone, email etc...
Paul
