v12 firmware problem
5 replies · 2,731 views · Started 19 August 2009
is anybody else having problem with there n97 with the new firmware? One problem that i have is that when i connect to the web on the nokia browser, i double click onto a bookmark and it freezes for about 10 seconds then the connection popup comes up. It never happen before on the v11 firmware. Is anybody else having the same problem and other problem with the new firmware.
When did V12 come out? I bought my N97 couple of weeks after release date and it's still running V10!!!
Where can I d/l V12 update for a Black N97 UK Simfree?
It tends to reset the default connection (for various and unknown reasons).
Go to settings in the browser and change it back to INTERNET (or whatever your default destination is) from whatever idiocy it has decided to use instead.
