Dear all,
I an wanting to listen to some football commmentaries, and previously could do so through the Real Player on my N86 8mp. However, the website concerned, BBC Radio Scotland Sportsound, now broadcast via the Flash Player 10.
Is there an application that can play this through the N86?
Many thanks
Stirly :con?
doubt it. Flash is usually part of the firmware
i think nokia not using flashplayer,but usually nokia have entered software for do that........
You are not the only one looking for a solution here. Why the BBC decided to change the format and potentiall disable the service on mobile devices only they know. If anyone has a solution I would be very grateful. Even an iphone solution would do. I've tried imobilecinema but that does not work.
At the risk of answering my own question, had a look around and found that Skyfire plays flash on my N86. Consequently, if you navigate to the radio station you want to listen to via the Skyfire web browser, you can listen that way. Quite a neat solution, and best of all, it's free!! :tongue:
Using Coreplayer and www.radiofeeds.co.uk I can get the BBC Stations to work
