Any idea which app must I have to open 3gp files?
3gp files?
Sorry, I mean is there any apps to run 3gp on the phone itself?
Nothing as yet as far as I know, you will need a 3650!!!
Bob
ok...
i know what is your problem...
you have HIPCAM.. and you can�t play the files you are recording.. right? 😉
well... HIPCAM have a REPLAY boton after you record the file...
and you can install Hantro 3.3 for example to play that files ...
HIPCAM open the HANTRO app to play the files when you click REPLAY...
cya!
AEFOX,
I think you misread the last post, Theran wants to playback on the phone not record on the phone!!!
B 😃
You are right Bob.
I am using CamRec to record videos with audio.
Problem is whenever I replay the recorded video, it prompt
No 3GPP Player
Found on the
Device
Anyone, any idea? Or do I really need 3650 to play?
rdgs
Theran
AEFOX is correct, it will play in Hantro if it doesnt open Hantro up manually and u will see the video u made in the Hantro screen just open it and play it in there! 😃
I need Hantro 3.3 is it free or ���?
Will they not play in realone?
I have realone on 3650 and it plays 3gp.
I think you can get it from www.real.com/mobile or mobile.real.com somthing like that.
Jish
I tried RealONE maybe im just blind but i couldnt find where to open a file? I only saw OPEN > URL and it wud ask for a url?
Wind's VideoMMS plays the files fine too.
[quote="Bob"]AEFOX,
B 😃[/quote]
I think you missunderstood AEFOX.
Hantro is not only a video recorder software but also a video player...
HI! ..
hehe!.. i don't answer to that because i knew that other guys will notice
that i was right...
You MEMPHISX for example! 😃
cya!
I was aware that Hantro was a video player as well as a recorder, but, was not aware that it played 3gp files, only mp4, The request was for 3gp file playback on 7650.
If Hantro does then I bow to your greater knowledge, if not I wll not!!!
Bob
hehehe!...
Nice BOB 😃
well... if you record something with Hantro 3.3 you will notice that the files are .3gp too.. that's why you can assume that it's play that format 😃
not a big thing really! 😉
cya!
Not having tried Hantro 3.3 I was not aware that it recorded in 3gp format.
As Hantro is not freely available, only to customers of the network that release it.
Legaly Theran will need to be a subscriber to get the software. I am not aware of any subscription free software that plares the files, but I am sure that Theran can find Hantro 3.3 on the net if required.
AEFOX, you are right again, I don't mind being wrong as long as a fellow AAS member is helped by it.
Bob
