Open message I have sent to the Ovi Suite Team:
Dear Ovi Suite,
I am not against change per se, as progress is important.
But I think it wholly wrong to replace one Application Suite with another, if the newer one does not do ALL the things the previous one did first
And I have spotted what appears to be a major functionality flaw in Ovi Suite, when compared with PC Suite, unless you can guide me different.
You see, in PC Suite, and indeed on my phone, all my Contacts have a NOTE field filled in, and in there I simply enter the text, for the name of the corresponding Caller Group I wish the Contact to belong to.
So for example, I have many of my contacts on my phone, with the text "Door Supervision" written in the Notes field, and many more with the text "Newcastle United" written in (my second employer).
There is a very important and useful reason why I do this you see.
Whenever I purchase a new phone handset, I can simply either use the backup tool, or a PC Suite based backup, of my Contacts data, to get all my names and numbers over to my new phone.
However, depending on the model of the new phone etc, quite often this backup and copy over to the new phone, will NOT however, restore the Caller Groups data, which is a fundamental and large element of my Contacts data.
By using the system I do, and having the name of the Caller Group each contact belongs to stored in the Notes Field, I can use PC Suite to easily fix this after a restore to a new phone.
You see, I simply load up Pc Suite, and go to the Contacts Editor.
I then enable the display of the "Notes" field in it, and then click this field to sort all my Contacts by the data contained in the Notes field.
Then I can easily highlight them in a block, all those with the words "Door Supervision" in the notes field, and then easily right click and add them to a Group with this name - and so on...
Alas, as Ovi Suite does not seem to have a column view for Contacts, and nor can you SEARCH on the Notes Field, there appears no way to carry out this function, or indeed do any such data organising of contacts, in the lesser, more basic Ovi Suite
So can you please advise where I am going wrong.
Or am I completely correct - you've LOST this facility in Ovi Suite, the new "Improved" replacement for PC Suite...?
