Hi everybody!
I'm searching the web for a Car Kit for my 7650, but I'm getting confused...
The problem is that some sites says the CARK 112 from Nokia will work with 7650 some says it won't. The Nokia Enhancentes page (http://www.nokia.com/nokia/0,5184,4916,00.html) says that Nokia 3650 is compatible with CARK 112 but it says nothing about the 7650. Otherwise some accessories dealers are sailing this kit for the 7650.
Since CARK 112 connects with the phone by bluetooh, what is the problem with the 7650? Does anybody has one? Does it works or not? Is there any other Car Kit for this phone?
Thankx :multi:
I don't think any bluetooth car kit will work with 7650 as 7650 is not Bluetooth Voice enabled.
Test it before buying.
And let us know if it works.
Nokia 7650 can not have any bluetooth hands free so the car kit will not work with it.............
[quote="trod"]Nokia 7650 can not have any bluetooth hands free so the car kit will not work with it.............[/quote]
Yes it can
Check out these BT Sets for 7650
Plantronics M1500
http://www.plantronics.com/north_america/en_US/catalog/display_category_type.jhtml?rootId=cat1150057&id=cat1220039&productTypeId=cat1220039
And Jabra for non BT phones
http://www.jabra.com/products/FreeSpeak_nonBluetooth.htm
The only problem is they are not available outside of the US
I do not believe my eyes. You are correct. I did not think they would come up with this idea. Thanks................
[quote="trod"]I do not believe my eyes. You are correct. I did not think they would come up with this idea. Thanks................[/quote]
If you manage to get hold of one, Let us all know 😃
[quote="Doc"][quote="trod"]I do not believe my eyes. You are correct. I did not think they would come up with this idea. Thanks................[/quote]
If you manage to get hold of one, Let us all know 😃[/quote]
I will. By the way thanks for the info.
I hope you guys have seen this one
http://www.nokia.com/cda13/0,5184,4238,00.html
Should be for sale soon...I'll get one!
On the topic, does anyone know where I can get a 7650 cradle for the car? Is there a better way to hold the 7650 up other than getting a leather case then using those stupid 2sided tape clips?? they never hold!!
[quote="Mig29"]I hope you guys have seen this one
Should be for sale soon...I'll get one![/quote]
This hands free will not work om 7650 because the 7650 is not capable of having 7650 bluetooth hands free. Sorry........
I don't think it will work with 7650. Sounds like you need BT audio.
Read the FAQ for product
4. Which phones work with the Nokia Wireless Headset HDW-2?
The Nokia Wireless Headset HDW-2 works with the Nokia 6310, Nokia 6310i, Nokia 8910, Nokia 3650 and Nokia 6650 phones. It is also compatible with other existing and upcoming phones on the market that support Bluetooth Headset or Handsfree profiles and are compatible with the Bluetooth 1.1 specification.
Back to top >>
5. Doesn't the Nokia 7650 phone support Bluetooth?
The Nokia 7650 phone does not have Bluetooth audio support, so you cannot use it with any Bluetooth headsets.
does the 7650 suck or what 😃
7650 doesn't seem to work with BT audio, if you go to "my bluetooth places" and then try and setup the 7650 to use your computers mic and speakers for calls it says that the 7650 doesn't support it... 😞
[quote="Anonymous"]does the 7650 suck or what 😃[/quote]
Sorry, I don't think it's possible... I installed symVacuum and it still wouldn't suck... somebody will probably prove me wrong tho? 😉
