T9 / Predictive Text - further info
(and @ Ewan here, for far too LITTLE mention of this, given his use of a 5800, and then a Qwerty device - winks at Ewan).
Let me say in simple terms, the biggest single thing that makes an otherwise superb browser that this is, completely useless to me, save as for a fall-back option, is indeed the text entry method issue.
Out of the box, T9 is indeed not possible.
And say what you will, when trying to send the shortest of comments to a friend's Facebook Status recently, I realised oh so very very quickly exactly why it is at least four years since I ever used multi-tap.
It took me a LIFETIME to enter it all in via multi-tap. Good lord, how bad.
So then I did a lot of research, and found that you can indeed "fudge" a way round this.
If you go into Settings, Advance Settings, and turn OFF "in-line editing", then you can sort of use T9.
Why do I say "sort of" ?
Because when you do this, from then on, when you click to fill in the dialogue, comment, or form field boxes on web pages, with textual data, you DON'T... it doesn't fill them in the box - it instead now brings up an O.S. based/styled entry box, much like the one you would see on your phone when being asked to enter your PIN number on boot-up.
And this will allow T9 entry, whereby the box itself will expand as needed.
And I have to say, this is wholly counter-productive, very confusing, and not very user friendly.
But as if that wasn't bad enough, a more real consideration here...
Whilst it gives you a kind of T9, it is NOT consist with behaviour across the rest of the O.S., as when you finish a sentence, enter a full stop and a space, and then type the first letter of the next sentence, it does NOT self-capitalise the letter, as it SHOULD do.
So as a result, you either use it at reasonable speed, and have wrong grammar, with no capital letters anywhere.
Or you MANUALLY remember to enter a new capital letter at the start of each sentence (usually by having to go back, AFTER you realise it forgot to), and as a result, end up with a typing speed that is marginally any faster than the horrible multi-tap referred to earlier.
So for those saying "you can turn on T9" - at least be realistic as to how it works, the issues, and the limitations to it.
And bearing these in mind, the end result is a Browser superb in most every other way, but that completely rules itself out as my main browser, due to this massive flaw.
