Maps for Dummies!
53 replies · 46,764 views · Started 12 November 2009
Perhaps the title of this article is a little unfair as some of the blame for the incorrect setting up and use of the built-in Maps application can be laid at Nokia’s door for not explaining it thoroughly enough in their manuals.
I hear a lot of complaints from people that their Maps application is inaccurate or slow and lags, particularly on long journeys. Also that Maps interferes with their handsets operation when used.
The reason for this is that the phone does not usually come preloaded with map data.
The map data that you see is loaded the first time you use the Maps application and is only for a l[B]imited radius[/B] of your initial position.
What does this mean in practice?
Well, let’s assume you live in London and are driving to Edinburgh. Once you leave that initial area that was downloaded by Maps when you first turned it on, your phone then automatically connects via 3G and starts to download map data as you go. This means that your calls could be affected, your widgets not updated, Maps appears slow and inaccurate, your battery is draining and you are incurring data charges.
So, how do we go about setting up Maps for use on the handset?
For the benefit of this article and to avoid confusion let’s get some definitions in place:-
MAPS is the programme on your handset with that name.
MAP DATA is the actual maps themselves that show your route (like paper maps).
MAP LOADER is the programme that you download to your computer to enable you to then download the Map data you require, free of charge. If you are using Ovi Suite this is already integrated into it. If you are using Nokia PC Suite or just want to download Map Loader separately you can do so from here:-
http://europe.nokia.com/explore-services/maps/download-maps
So, let’s get started...
1. If you have previously used Maps or have upgraded your Maps programme (if not, then go to step 2.) then I would suggest using the phones built-in File Manager (usually found in the Office folder) and navigate to Mass Memory ( E: ) or Memory Card and delete the folder named “cities”. This contains your initial download and effectively returns Maps back to its starting point. The other file to delete is “qf”. Don’t worry these files will be restored in step 3.
2. Now for the initial setup of Maps. Before using the Maps application you will need to check that certain settings are in place. Depending on your phone (refer to your manual), these are usually found under Phone settings > Positioning. Ensure that Assisted GPS, Integrated GPS and Network based are selected. Now go to Positioning server and choose your Positioning server use setting, I use Automatic. Access point (this is your operators data service) and ensure that Server address is configured to supl.nokia.com then Notation preferences are your choice.
3. You now need to take your phone outside with an all round, clear view of the sky. Preferably on a clear day with no tall buildings around. A window sill, conservatory, porch or such like is not a good idea. Now, with the slider open, go to Maps and depending on your version of Maps, you may need to select “My Location”. Leave the handset to get its initial fix on the satellites and download its limited Map Data, usually about a radius of 30-50 miles. A lock on four satellites is preferable. This may take up to 20 minutes so please be patient. If in doubt it is better to wait longer than rush this step. Once you have an accurate fix and the limited Map Data has been downloaded you can then go to step 4.
4. Assuming that you will want to travel outside of the limited area that has been downloaded to your phone already you will now need to connect your phone to your PC and open either the Map Loader you have installed or Ovi Suite, Maps. Confusingly enough, if you use the Map Loader programme it initially asks you to delete your existing Map Data from your phone, using the delete button, before commencing download of your chosen Map Data. I would ignore this option as it is designed to replace out of date data.
5. You are now ready to download your chosen Map Data. Depending on your travel requirements you can choose to download a single U.S. state, a country or countries, a continent or even the world (about 4.5GB). You can also select the voice to use for navigation guidance. Up to now everything has been free and you could use your device with Maps as it is in a limited fashion for navigation and route planning.
Maps Booster
This application from Skyhook can be downloaded from the Ovi Store and costs �3. It uses wifi to enhance your GPS signal, particularly useful in built-up areas. It offers a quicker lock for the handset and since installing it I have found that Accuweather's "Current Location" feature works well, even indoors.
http://www.skyhookwireless.com/mapsbooster/
*UPDATE*
Maps Booster is now of dubious benefit if you are running the latest version of [B]Maps, v3.04/3.06, as this includes Nokia's own Wi-Fi/Network positioning.[/B]
N.B. If you do download v3.06 don't forget to update your maps data as well.
I hope this helps and make no apologies for the length of this article as I hope it may solve some of the problems that people new to Maps are experiencing and may be blaming their handsets for.
Ian,
What is the purpose of your step 3 (getting minor download of data and initial fix) before using Nokia Maps Loader and getting an entire country?
I've done multiple loads, deletions and reloads (of map data, cities, qf file) and have had the antenna repaired and I still see poor performance (speed-wise) and poor accuracy (positioning-wise) from my N97 GPS.
I've done all that you suggest with the exception of step 3.
One item that seems to be a very poor design in their Maps application is it seems to pull the a-GPS data from the point-in-time that is over a day old rather than from the nearest tower that you are in communication with.
A poster on the Nokia Discussions forum says that the initial a-GPS file created with your first map load is critical and that you should delete and reload the Maps application data again-and-again until you get one that is accurate.
Does this sound like a very well-written program to you?
In the near future I intend to run some controlled tests to see what the sensitivity is to the different variables involved:
1. Is there still a hardware problem with the internal GPS? To test this...use an external BT GPS receiver.
2. Is a timing problem being caused by other applications that cycle-steal in the background? (Accuweather, Facebook, Messaging). The only way to really test is to UNINSTALL these applications and try running without.
3. There also seems to be a "feature" (or should I say "bug"😉 in the Maps application that always seems to assume that you are on a roadway even though you are on foot or in parking lot. This would explain a lot of the jumping around. I'm not quite sure how to test this, but I'll start collecting data to see what falls out.
The GPS is the last thing that is not working to my basic satisfaction on my N97 so I am ready, willing and able to test this and share my observations in an effort to get Nokia pointed in the right direction to get it fixed.
Excellent guide
Ian to update maps (I've already downloaded full Europe maps in the Maps 3.xx rel) do you have to delete all your exisiting maps or is there a update feature (haven't tried doing it under Ovi suite)?
Just a quickie on the data used, I have a prepay N97, to avoid large data charges i have downloaded the maps i need via map loader, I have since turned off network connections as i already have the maps, I now feel i need a more accurate position so i was going to re-activate network connections, My question is how much data will be used if i use assisted gps when i already have the maps downloaded?
Assisted GPS cost 3-4kB , to get a fix . Right after you can disable the aGPS . So while Navigating only the default GPS is used .
When you haven't downloaded the Maps to your phone , you will need datatransfer to get the appropriate Maps . This is a big data consuming situation . Example : Google Maps .
😊 Regards jApi NL
Hi, rdcinhou,
The information in my posting has been gleaned from 4/5 years of dealing with Maps, since the N80 in fact.
Most of that which I have related came directly from Nokia/Ovi Maps, including item 3 which I have always done on my phones since, as per their instructions.
Since I am no technical whizz I cannot explain why this needs to be done or how it works.
All I can say is that:-
1. On an unmodified N97 I am getting a quick and accurate fix and holding a lock. This not only applies to my handset but also to others that I have configured in this way.
2. Possibly the answer may lie in the 2nd paragraph from your edited quote.
It is difficult to compare UK and US GPS as I'm given to understand, by yourself I believe, that the GPS signal in the States is capped or dumbed down for security reasons. Therefore making it less accurate.
Also, certain service providers, most notably AT&T, do not have a strong/extensive 3G/HSDPA network. Again, this could cause problems.
One tip I came across, I can't remember where, was that prior to Step 3 one could do the following to ensure the strongest initial signal:-
Menu > Settings > Connectivity > Network > Operator selection... change to Manual.
You should then find, after the handset has searched, that you are offered all the networks in range, 5 in my case.
Now select any network, other than your own, and try to connect.
You will, of course be refused. Repeat this step 2/3 other times and then finally select your own service provider which will be accepted.
You should now have the strongest signal available for your location and can then proceed, after switching back to Automatic, to step 3.
I actually carry out the above about once a month as I am led to believe that sometimes mobile phones can "stick" to a given tower rather than searching, particularly if signals are weak. It also helps with "stuck" texts as well.
In conclusion, it wouldn't hurt to try Step 3, perhaps coupled with the above signal search as it cannot do any harm but I make no guarantees as there are other variables as I have mentioned.
Perhaps, if anyone else has tried the method I've described above in full, they could post their findings.
snoFlake wrote:Excellent guide
Have you downloaded the the latest Ovi Maps prog, v3.03, to your handset?
If not, I can thoroughly recommend it. You can get it here:-
http://betalabs.nokia.com/ovi-maps
As for updating the Maps data itself, I prefer to start afresh by deleting "cities" and "qf" and just re-downloading the required map data.
There was, I remember, a Maps Updater app for the PC which I cannot seem to find on the Nokia site now, although it is available here:-
http://www.softpedia.com/get/Mobile-Phone-Tools/Nokia/Nokia-Maps-Updater.shtml
However, I could never get it to work I'm afraid. I don't know if anyone else has tried it.
Hope this helps. 😊
Zyyb wrote:Nicely put Ian! This should be a sticky as a GPS guide
Thanks Zyyb,
I'll leave it to the mod's to decide but it may save a lot of postings if it were a sticky. 😃
@ ian
Thanks, no I haven't tried 3.03 cos phone's been in the shop for last 3 weeks (cam and GPS - yawn) 3rd attempt at getting them to do it right rather than reflashing it 🙄 . I might give it a go but can you install it not on the C: or can you unistall 3.01 which came with V20 I think. Only I'm a bit loath to squander precious C: having 2 maps apps on it (ridiculous isn't it) as I've had permanent space problems and I know I'll be downloading messaging and probably keeping messages on C: (if I can) becasue saving to E: keeps resetting every time plug it in to PC and being silly I've occasionally forgotten to reset which has been a real pest
Sorry snoFlake but it only installs to C: (good old Nokia) at 7MB and you can't uninstall the built-in Maps.
I have it on my C: drive which is much better for space after v20.
Ian
I just wanted to say that yesterday i followed your instructions to the absolute letter and have successfully loaded maps to my phone with great GPS reception 😊
I was going to try it out today with a little further than local travelling but sadly the weather is so bad here that i've decided to stay in ..... and i can make my own way to the kettle 😃
Thank you
Followed instructions to the letter. Still have the same old "jumping" and "lagging" positioning with 5-7 satellites reporting. GPS is the last thing that is substandard on my N97.
Maybe the problem is geographic in nature...i.e. data in the drivers for one (or more) satellite(s) could be off/typoed which is causing the problem for some but not for others.
My location is Texas, USA.
Anyone else still with GPS issues, please report your general location.
UPDATE: I believe the positional error, jumping and lagging is a pure software problem with current version of Nokia Maps itself. I have great response and great accuracy with Google Maps and Trapster, both of which use the internal GPS. The problem still may be "local" in that it could be a map data or satellite almanac data error.
Update...
Even on repaired N97, there is a tendency to lose the satellite fix with the unit heats up.
This running hot/loss-of-fix seems to occur:
1. Immediately after being on a mains charger
2. During long trips where GPS display is set for continuously on
3. Charging on car charger while using GPS
Looks like an engineering error in the design of the circuit's heat rejection and/or lack of temperature compensation with regard to GPS processing.
Immediate workaround is to use an external Bluetooth GPS.
No wonder Nokia lists the Nokia Bluetooth GPS Module LD-4W in the Accessories listing for the N97!
Just updated my Map's posting to include details of Skyhook's app called Maps Booster which uses wifi to enhance the location fix, a bit like Google Maps and iPhone.
I have been using it for about 6 weeks and it has certainly improved the speed of my lock, particularly in built-up ares, so much so that I can use "Current Location" on Accuweather indoors. Once installed and set up it sits quietly in the background like Assisted GPS.
The app costs �3 and is available from the Ovi Store. More details here:-
Now that we have maps 3.03 any chance on some new pointers.
For example do we still have to do that figure of 8 thingy to get the direction right, and is that what the pointer is for in the bottom left of the screen.
Is there a way to toggle different points of interest or add our own overlays?
Is there a way to "force" the map to show you driving along the road in the correct direction (like it does in navigation) It's very confusing watching the screen showing you driving sideways.
Also it would seem that Skyhooks Maps booster no longer works with the latest firmware update.
riverboat wrote:Now that we have maps 3.03 any chance on some new pointers.
"Figure of 8 thingy" is still required to calibrate the compass (now the pointer at the bottom of the screen).
"Is there a way to "force" the map to show you driving along the road in the correct direction (like it does in navigation) It's very confusing watching the screen showing you driving sideways."
Not sure what you mean on this. If you are not using navigation and have calibrated your compass it should show your map aligned correctly.
Maps Booster is most definitely up and running after v21. The problem seemed to be with v20 and Maps v3.03 and Maps Booster but all good now, particularly in built-up areas and indoors.
[email protected] wrote:"Figure of 8 thingy" is still required to calibrate the compass (now the pointer at the bottom of the screen).
Cheers for the quick reply. okay the figure of 8 will ensure that the screen shows me driving the right way.
Is there a compass feature on the 5800 and if so can it be calebrated, so the map can show the correct orientation when driving (but not in guidance mode) ?
How about the cameras ...how to get them to show?
Regards
Well i still find i get a fix very quickly, but getting the compass to go green only works about 30% of the time, no mater which way i wave the phone about...
Also can anyone tell me what the "optimised" route setting does?
riverboat wrote:Well i still find i get a fix very quickly, but getting the compass to go green only works about 30% of the time, no mater which way i wave the phone about...
I would recommend installing Maps Booster from the Ovi Store, (�3).
A great piece of kit that, once installed and configured, sits quietly in the background and enhances your position, even indoors. Speeds up getting a lock too, even in built up areas.
Works with not only Maps but any GPS app, AccuWeather (shows Current Location for me), Google Maps, etc:
Optimized route takes into account all of your criteria entered into settings along with any updates.
like i said i get a fix very quickly, it's just getting the compass to go green that is the problem.
I find just standing still and repeatedly tapping the compass indicator will cause it to turn green. However it loses it orientation after ten seconds or so.
Does maps boosterreall help the phone know which direction i'm facing?
I don't mind shelling out the �3 it's just that as it uses wifi and i live in the country i didn't think it wold be much use to me,
Also i would prefer not having stuff running in the background if i can help it.
riverboat wrote:like i said i get a fix very quickly, it's just getting the compass to go green that is the problem.
Maps Booster is like AGPS and only runs when you require it (like AGPS).
It enhances and speeds up your lock and its accuracy and therefore "turns your compass green" and this in turn orientates the map.
Works great in the country for me as I have it set to my 3G service (only uses a few kb's of data).
newbie here,
trying to get Ovi maps working on my N97, downloaded the latest firmware fine through PC Suite.
Then tried to Download maps, which then opens up the website, so I go to the Ovi maps page and tell it that I have an N97.
I click on OK which then opens up 'Download Map Loader'.
I select English and click on Download.
The file download screen comes up for NokiaMapLoaderSetup_ENU.exe
I click on Run.
The security warning comes up asking if I want to Run the software, I click on Run.
It tells me that it requires that another piece of software(Microsoft .NET Framework 3.0) is installed first so I click Install.
Then it tells me an error occurred while downloading the file and would I like to Retry.
I click on Retry.
It does this a couple of times and then fails to do anything.
I have also tried following the other instructions on the nokia/support website which say:
Go to Menu � Applications � SW update on your Nokia N97
Select Ovi Maps from the list of available updates
Select Options � Start update
This gives me a screen which says Refreshing list of available updates.
Then Refreshing failed try again later.
This has been going on all day(well, 4 hours anyway).
I have since followed the instructions for dummys here and got it to stage 3 apart from it didn't download any maps even locally. although it did give good strong satellite lock and was able to give me co-ordinates reliably.
Brought it back in to try the above again but still no joy.
I've turned off AVG and Windows Firewall to no effect(didn't restart the PC).
Help!
Very helpful thanks very much,
managed to get maps_installer onto my desktop and also managed to get Ovi maps installed onto the N97 as a program but am now wondering how to get the maps installed.
Got to stage 3 of the instructions on the original posting on here, so now have satellites locked although no mapping was downloaded automatically.
If I click on the maps installer on my desktop it keeps asking if I want to install teh application to the N97 and then asks me to complete the install through the phone.
I think what I am looking for on the phone is how to now download the actual maps.
Now really short of time due to leave in 30 minutes for Hungary and trying to get that mapping sorted on the phone.
Thanks in advance.
You need to install Ovi Maps v3.03 to your phone using PC Suite, or Ovi Suite, and with the phone connected via USB.
Next you need to follow the instructions from step 3.
Hope this helps.
UPDATE
It's worth updating your phone's maps prog. to the beta v3.04, available here:-
http://betalabs.nokia.com/apps/ovi-maps-beta-for-mobile
It is fast and accurate and now includes WiFi network positioning to enhance the GPS and AGPS signal. Coupled with the Maps Booster app it gives me my location to within 10-20 metres... indoors!
Minor changes to the UI, GPS signal bar removed as I'm told that Nokia consider it redundant due to the number of positioning methods now available on the phone. Also zooming in and out is faster as is the satellite view.
Still has FREE voice navigation, etc:
I have been the first to criticize Nokia in the past but they have really pulled all the stops out on this one! 😊
