Create new Icons with PC Suite!
9 replies · 2,348 views · Started 13 March 2003
Nokia PC Suite
The Nokia PC Suite is a software package compatible with your Nokia mobile phone. With the PC Suite you can manage the way your phone looks and works, feels and sounds. Use it to edit your phone's settings, contacts and data; synchronize calendar and contacts data between your mobile phone and a compatible PC. Create new display icons and convert ringing tones, and manage your phone's modem setting and WAP access points. All quickly and easily on your compatible PC.
Yes you can according to Mr Nokia! errr how?
Sorry... my bad:
http://www.nokia.com/nokia/0,5184,865,00.html
I guess it's a typo, but nonetheless 😞
No mention of it in the next page:
With PC Suite for Nokia 7650, you can share information between a compatible PC and your phone, install software on the phone, configure phone settings, and make backups of phone files. You can also synchronise your calendar, contacts and tasks with Microsoft and Lotus applications, copy and move images on your PC and phone, and copy contacts and calendar information from another Nokia mobile phone or a Palm device.
It must be just copied from some other PC suite for other phone.
Or it means something else...
As much as i know, pc suite for 7650 use some type of plugins to do things. So maybe nokia will release them, or may sell them as a connectivity pack. Who knows...
Could they mean that you create new icons when installing a new app via PC Suite?
Could they be so stupid???? 😃
[quote="MemphisX"]As much as i know, pc suite for 7650 use some type of plugins to do things. So maybe nokia will release them, or may sell them as a connectivity pack. Who knows...[/quote]
yes they will definetly sell 😉
