Thank you all for your help, I decided to give Sygic a try and purchased it.
My first thoughts are.
The download are 1.9 Gb so I would recommend fast Internet, in my case their server was very slow and it told me it would take 7 hours, so I just left it to do it's business while I went to work😊
The file it self contains versions for Windows, Android and Symbian/Symbian Touch, which is ok.
You install it to your pc and it installs a program called Sygic Assistant, in here you select which maps to install and language etc. In my case Nokia N97(which works perfectly well) what surprised me was you can't select which platform, so it installs them all on your phone (Windows and Android and Symbian), I find that a bit weird to say the least, you then manually have to select which one to install on your phone.
I then spent some time deleting the unwanted versions, and modify the .ini file for safety nagscreen and some setup including activation.
I took the first drive last night from Dovedale(derbyshire) to Derby, and it performed perfect kept me straight on the road no problems what so ever.
This was using the internal GPS on the N97, it took a bit of time to actually lock on to the satelites, but after that it was perfect. I wonder if that means my GPS doesn't need to be fixed?
The only thing I can't get to work are the convertion of Favorites/POI from TomTom to Sygic, I have used the sygic converter, and I have converted from TomTom to tab delimeted file first. I placed them in the map folder, but no success at all.
Sorry for my long rant, just thought it might be useful for others.
Cheers
Mike
P.S It really is sooooo much like TomTom, that I thinkTomTom are involved in that company somehow apart from the Teleatlas connection.
