I've downloaded RealOne player and it works Ok. When I try and connect to streaming media, however, it starts the connection and gets the info about the clip, but just before the clip starts, a message pops up saying that the Audio Device is already in use.
Also, halfways through Britney's 'Hit Me One More Time' (which I downloaded from N9210), I get an 'Out of Memory' error, but there's nothing running except Phone, Desk and the player.
Any ideas?
mine also closes in the middle of vids. dont know why
hope you got the britney vid to look at her tits, not cause you liked the song
Same thing over here.
<center><B>OUT OF MEMORY</B></center>
Right in the face every freaking time...
<B>DOOOOOH</B>
Funny thing happened....
I started RealOne with some other applications in the background and, for some reason (I guess it is detecting less available memory), it is showing a smaller screen and the whole things plays right through.
Still no joy with the 'Audio device already in use' business though!
Hello there. i have a question i downloaded RealOne Player but i can`t find a good URL for do you now any??
Thankx
If you select 'Media Guide' from the menu, you'll be taken to a web site that contains plenty of links.
The clever thing is that if and when you select a link, the web application saves the file, shuts down and the RealOne application takes over, so the Web application doesn't cause any memory probloids.
Let me know if you get streaming to work because I'm having trouble with audio.
Thanks!
Hmmm... maybe i should try this...
Im having the same problem as i installed the RealOne Player but when i want to play a .RM files,a 'OUT OF MEMORY' note came out....Hoping that this problem can be solve soon....Anyway,thanks all....
If you go to Tools -> Preferences, turn off 'Auto Zoom Small Images'.
When I do this, I can play video files all the way through!
I just have all settings as default. I have had no audio errors at all with the links I have streamed. One problem with RealOne is it appears the maximum bandwidth is 43200. If a stream over this is accessed it will usually say try a higher bandwidth and will not even attempt to connect to the stream. But on a whole it does work well for alot of stuff. Im trying to find a site that streams whole movies. Make sure you have no other audio device open, possibly even voice recognition. A site here in Australia is abc.net.au. Most of the streams on here work. But its only our news. But maybe a good stream to test it with. Or an ozzie radio station that works is found at abc.net.au/triplej/listen and click on the realplayer link.
Cheers
Ian
I think it is a firmware thing I'm experiencing then.
I get the same error if I play a local file while I have a data connectrion active. It's a bit odd mind since I can play normal WAVs while on the phone.
Never mind, I'll just have to get my firmware....... firemed up!
Yeah - it's kewl...i set files to normal video not presentation when i make them 4 the 9210 real1 player, to play from the mmc - the quality makes nokia's NIMs look appalling! i use switcher to kill applications to free memory. i think the streaming will only work on the 9210i over HSCSD.
Somebody PLEASE HELP ME!!!!cry
I've installed the new RealOne Player and it seems like ok...But when i play a .RM files,after few seconds this note suddenly come out
Application Closed
Application RealPlayer_Mobile_Thread_5
Reason code KERN-EXEC
Reason number 3
What this mean?How to solve it?I really hope that i can use the RealOne player as well as your one.....
NEEDING EVERYBODY HELP.....
THANK YOU.....
Dont know what to say about that problem. With all these problems people are having maybe a format might help. Just before I installed the new Realplayer One I formatted my phone. Since installing the new player I havnt had one problem with it. I have just watched a 15 minute video with sound. Ive got v4.13.
Is there anyone using RealOne Player on 3.62 version?And izzit ok and success?Im using 3.62 version and using the RealOne but i can't run well any .RM files.I've already formatted my 9210 and its MMC card but still having the same problems...Any comments on this?
Thanks....
The player works fine on n9210. But the max framerate is to low to really enjoy clips.
