H
I just got the N97 Mini a couple of days ago.
When I recieved the phone, it was equipped with V10.0.020 firmware, everything was working fine untill did the automatic firmware upgrade through the phone.
Before the Upgrade:
Text message time was appearing fine. I am currently in Canada (I have a british phone) and I set the time zone settings to Canada and even had the automatic time set switched on.
After the upgrade :
When I have the proper time zone set (Canada GMT - 7) the time on the text message recieved would appear 5 hours head. If I have it to GMT or skip the time zone setting the time would appear 2 hours ahead.
I have been searching for a solution however have had no luck.
Tries to rectify :
I tried a hard reset *#7380*
I tried the soft reset
However none of these managed to roll back the firmware to factory firmware. It appears to keep the new updated firmware. which is a custom version V10.0.020.209.XX
Does anyone know a solution to this issue?
I would not mind rolling back to the version in the factory settings.
Please advise.
Thanks!
