ok, it is taken from all of the anti x6 revolution group doesn't truly understand the difference between x6 and 5800.
you all people make me laugh!!! killing me till i found my self dead laughing at you!
here are the comparison:
x6
1. capacitive screen
2. 5 mpx camera with dual led flash
3. 16 gb built in memory / 300 mb phone memory (ROM)
4. scratch proof screen and made purely with glass
5. plastic design
6. symbian 2 series 9.4
nokia 5800
1. resistive screen
2. 3.15 mpx camera dual led flash
3. 81 mb phone memory (ROM) / card slot up to 32 gb
4. plastic screen / non scratch proof
5. plastic design.
CAPACITIVE versus RESISTIVE
You people should understand that the term itself really makes a difference. A very simple example is why don't you try to put a pressure on a bunch of tissue versus the bunch of cotton? which one is easier to press? that explains very well for the capacitive. Just to awaken your narrow minds.
5megapix versus 3.15 megapix
Do you know how much a lense cost? So are you telling me that 3.15 is better than 5 megapix? another laughing story from you guys! hahahah!
It was truly an upgrade scientifically and logically. For those people who have no experience with photography, never use this kind of statements as you are proving yourself funny.
16gb on board (built in) versus sd expandable slot
Do you people can imagine that x6 is slow, sluggish and worst than 5800 without knowing first the ROM capacity of both phones? x6 has 300mb ROM compared with your precious 5800 of 100mb ROM.
So it means though you were able to expand up to 32 GB, it will be useless as your phone will just get stack, dead and useless. You will wish to throw your phone.
Just a trivia: for every 8gb memory card there should be at least 100mb ROM to process and accomodate the datas being stored on the expanded medium. so if you were claiming that 5800 has the capacity of holding the 32 GB in a full memory state, you might be dreaming that your phone has a snap dragon processor that can hold the frequency of processing to produce great results on its GUI on how it responds.
So compared with X6 that it was built with a sense and logic, 16 gb board memory is reasonable for it to take and possible to carry on as they give allowance to the ROM memory of 100 mb.
So tell me, which is really freak and shi*t with their words being bestowed which haven't proven and makes none sense reviews? Illiterates!
Plasticky design???
Was your nokia 5800 made of steel or gold? hahahaha. Do you really know the meaning of plastic and on how it looks like? have you tried to view closely with your nokia 5800? was it made of plastic? isn't it??? HAHAHAHA!
and considering the screen guys of your nokia 5800, even your nails can scratch it over and proves that it's design was also a big failure knowing that a touch screen phone is not scratch resistant!
You know the problem with you guys! you just don't have the money to buy these phone and claiming to hold the fame by sticking on the minds of the viewer on every reviews posted on this site that it was a failure to have X6.
But the truth is, it was a big and regretful failure to follow and believe your reviews which are evidently FUNNY.
PEACE GUYS!
by the way i have nokia 5800 on my hand, nokia x6, nokia n97, HTC 2 and SATIO. I am a business owner of a celfone shop in the philippines. So I know what I am talking about.
Just a quick final statement, I am using my nokia 5800 as an alarm clock as I found it very useful on that!
Cheers!
