Change Startup Logo
10 replies · 3,617 views · Started 03 May 2002
Hey again! I put my question out here again. Does anyone know any program in symbian for the 9210 that can change the STARTUPLOGO ?? If so, where can I find it and whats its name ?? //Thnx
Logomanager can be use to change the logo and the phone side! But you will need the right cable (the one in the box will not work, and neither does IR for some reason????)
If you are talking about the colour logo on the pda side will its a image on the z witch is read only!!!
I tried to make a nother image with the same name on c but still no luck!
Dont think changing this will happen any time soon.
What i mean is a program made in symbian for the 9210 and no windows program. The logo I want to change is the logo on the phone side... //Thnx
Hai all...
Currently im using Logomanager and i try to connect my 9210 to the Logomanager but it doesn't work.Which type of cable that i should use?Thanks all....
I have heard from a friend. if you have eMassiging en jou send a operator logo to your self it works. or a different programs to send operater logos. try it.
Yes, I know how to change the operatorlogo but the logo I wanna change is the STARTUPLOGO. And I want to do this on a program made in symbian for the 9210. A guy on Nokia told me that there is a program for 9210 that can make this happen... //Thnx
Yep! I wanna know that too! So, how to change the STARTUP SCREEN??? (not operator logo! User posted image)
- Jay9210 // Finland<font size=-1>[ This Message was edited by Jay9210 on 2002-07-01 0829 ]</font>
[quote="akn78"]Yes, I know how to change the operatorlogo but the logo I wanna change is the STARTUPLOGO. And I want to do this on a program made in symbian for the 9210. A guy on Nokia told me that there is a program for 9210 that can make this happen... //Thnx
[/quote]
I guess your Nokia guy is a liar... until today there's still no such apps dude... you can change the STARTUP LOGO with MBUS cable and LOGOMANAGER... this is what i use anyway...
I also have CELESTA MyStyle which i think is really cool coz i can change my operator logo without having to SMS it to myself...
[/quote]
You can change it - but only to Text, not a graphic.
From phone side - Menu 3-2-3 - change Welcome note.
To chane it to a graphic you have to use Logomanager or something.
