hiya.
how do i asign a username and password when i go on the interent on the p800.
i want to do this because i press the blue button on the side of the phone by mistake and it goes on the internet and i dont want it to beacuse i have no gprs package.
and please could you tell me what the token name, username and activation license on rsa security is?, under secure tokens and the token name serial number and authorization code for new safeword under secure tokens.?
thanx very much
From memory, if you dont have GPRS / WAP set up, then when you press the internet button, nothing would happen
If you had a free month of GPRS and have the settings already set up, then go to control panel -- connections -- internet account -- and delete your GPRS settings
therz got to be a way to put a password or some kind of validation on before you can access the net. or someway to diable the blue button!!
NO IDEA, I WANT TO ALOS KNOW HOW TO ACTIVATE THEM SECURE TOKENS????
You can disable the "blue" by installing the screenshot program and keep that running, you can also use the "key"lock. Or you can easely tell the phone 2 promt password on screen saver exit, that's the best ideas i have
If you have handy day you can also asign this to the blue button. Handy day will then have an ainternet connection option below which is a great shortcut! 😊
