Using EProfiles Pro 1.6? Try this
12 replies · 2,831 views · Started 20 March 2003
If you are using profiles Pro v 1.6 try this
Open Eprofiles. Go to Options. Select personalise. Go to Backlight select On if charging. Press back. Select Options - Activate.This should all be done with General highlighted. Exit Eprofiles.
Now plug phone charger in. Turn off phone. Turn phone on whilst charger connected.
What happens when phone restarts? Please post answer.
[quote="wannyondeathrow"]Light dont stay on whilst charging.[/quote]
Did you restart phone whilst charger is connected?
nothing happened..
But when I did it to another profile and added an alarm sound and calendar sound to it, after the phone started it started sounding the alarm non stop.
Tried it to the other profiles aswell and it still sounds. So I guess when I add a new alarm sound or calendar sound to the profile, and restart the phone it goes off. do'h!
[quote="Rod"]nothing happened..
😃[/quote]
Yes it seems once you set up a mid file as an alarm. That alarm sounds when you restart with charger connected. It is only stopped when you restart phone without charger.
I've contacted psiloc, will post their reply.
Ok I've got a reply from Psiloc they sent me a copy of EProfiles Pro 1.7. It includes a new alarm enhancer which fixes this problem.
Contact them if you have the same problem.
i had the problem, that when you change alarm ringtone you lose vibrating setting when alarm is ringing.
no answer till 3 weeks 😞
so be glad that there was an answer for you 😉
[quote="walda"]i had the problem, that when you change alarm ringtone you lose vibrating setting when alarm is ringing.
so be glad that there was an answer for you 😉[/quote]
Did you contact support at psiloc. They've always replied within 24hrs.
BTW I haven't been able to duplicate your vibrating problem?
Extended Profiles Pro version 1.7 is now available on Psiloc site
Besides fixing the abovementioned bug
it also allows to activate a profile for a specific period before returning to general profile
Animated gifs in background now use less power
Allows you to switch profiles when connecting or disconnecting charger
Keylock has been changed to allow a specific time period before activating.
wow! is there anything left to add in terms of profile personalisation?? 😮
Well done again Psiloc (not only quick bugfixes but also new functionality)
Paul
Maybe nokia should hire psiloc for the inbuilt programs of their next series 60 phone... Again they show the way in developing along with wildpalm and inspire other developers...
I'm sure Psiloc would be very happy... meanwhile, their suite of products is becoming "must have" for serious users, so they will get their reward that way in the short term
Paul
In my opinion, some of Psiloc's tools are already indispensable.
eProfiles Pro, for example, was one of the first programs I tried on my 7650, and I can't imagine my phone without such basic functionality (in my opinion).
miniGPS is another program that I've grown to love. If only there was a way to merge the two applications' functionalities...
I bite my tongue, since by the time I've thought, 'this could be a cool extra function in eProfiles', Psiloc tends to have a new version available with exactly my wished-for functionality..
Good for Psiloc!!
