Hooray finally got bluetooth to work but need help-pcsuite
4 replies · 2,000 views · Started 22 March 2003
at last ive finally got the poke2 btoo9s adapter to work 😃
i couldnt send files back to the computer well pics and progs any way and now i can. All i did was download the newer drivers so thanks to who ever helped me
How ever i just need to know how i get pc suite to connect to my phone cos when i go into it nothing happens and i tick every port and none of them connect to phone so can any one help us out
cheers
At last!!
It was worth fighting with it my friend.
Open mRouter - tick ALL the blurtooth com ports.
Then go into your bluetooth neigourghood and double click the icon for your phone - then double click the icon for Serial connection.
You might get an error - don't worry - look at mRouter and it should spark into life, open mRouter again and see which COM port it has connected on and untick all the rest.
Open PcSuite and you should be in business 😉
Best 😊
Will
1. tick the first bluetooth (maybe com3 ?) com in mRouter list
2. look in the bluetooth configuration in tab "local services", what com is "Bluetooth Serial Port" set to. (maybe com7 ?)
3. tick that com port in the mRouter too.
4. should start connecting. (takes about 5-10 sec)
if not try again clicking that last com.
Hope that helps.
cheers people finally i am rolllllllllling and i was so close to taking it back and i bet a lot of people do but whats with the error thing any way why does it say that
Although I am not sure, I think 7650 denies the connection the pc is trying to make and then the 7650 tries to establish a connection with the computer. Although the connection that the pc asked was rejected the 7650 makes the same thing and the computer accepts it. Older version of widcomm drivers were rejecting the connection trying to be established by the 7650... This must be a symbian bug because P800 users get the same error when they connect it through bluetooth.
