Battery Problem.
39 replies · 61,989 views · Started 15 September 2010
Hi, guys I have a battery display problem, the battery bar wouldn't show the correct battery remaining, but i found out that everytime my screen flash 2 times then the battery bar with drop but sometimes wouldn't, sometimes it with hang and my battery can't last for 2 and half days(note when I brought new it can last) I did change to new battery as I thought battery already k.o.
Thanks Regards 😊
Try iON Battery Timer from Nokia's Ovi store.. basic version is free but it gives you a very good idea of the condition your battery is in
On 10-08-2010, I bought the Nokia E90 Communicator.
Case 36,499 costs.
But its really sad to say, that the
Battery talk time is only less than an hour
& STANDBY time is less than 36 hours.
Pretty Strange.
The Battery was new? I always keep a spare batery available anyhow.
What charger are you using?
Do you use the e-mail and web browsing in this less than an hour talk time?
I have a 79 corvet that has a 383 stroker in it. I recently found that the alternator was bad. I have replaced the alternator and a new dry cell battery.
Most Autozones/Checkers, names depending on where you live, are a great and free asset to this particular question.
I think your alternator is bad.Sometimes they can drain your battery.It also could be a bad voltage regulator than can do the same.
go get your charging system checked,,sounds like your alt is weak,,needs to be overhauled.
I got a kindle for christmas and it's awesome. The only problem is after i put it on sleep and come back to read 90% of the time it says critical battery.
i mean it can turn. but the red wire turns with it at the same time. soo is there any way i can do something to diconnect the red wire from the battery soo i can swapp it out.
I have a 79 corvet that has a 383 stroker in it. I recently found that the alternator was bad. I have replaced the alternator and a new dry cell battery. I
I just have to say ... THANK YOU THANK YOU THANK YOU ...
you have just saved my life
and us a lot of money
I need some help. I just replaced the alternator and the battery in my truck and it is still showing a low battery on the gauge and the battery light is lit up on the dashboard.
right now i disconnected the battery and im going to let it rest for a 1/2 hour and see if it does any good ...
