Battery Problem.
39 replies · 61,989 views · Started 15 September 2010
I recently found that the alternator was bad. I have replaced the alternator and a new dry cell battery. I have tested both the battery and the alternator and I know that they are good.
I think your alternator is not good enough to use thats why you are facing such problems.
Thank you
The battery is not as long as possible, to no protection circuit of the battery filled namely should stop charging, or cell because of fever or overheat impact performance
e90i wrote:Hi, guys I have a battery display problem, the battery bar wouldn't show the correct battery remaining, but i found out that everytime my screen flash 2 times then the battery bar with drop but sometimes wouldn't, sometimes it with hang and my battery can't last for 2 and half days(note when I brought new it can last) I did change to new battery as I thought battery already k.o.
Thanks Regards 😊
I think your charging system is out of order. Get it checked.
When the battery is not the longer the better, after the battery is full of no protection circuit which should stop charging, the battery will affect performance because of fever or overheating
