9210 contact database to P800??
2 replies · 1,948 views · Started 25 March 2003
can anyone trell me the easiest way to trasnsfer my contact database from my 9210 to my P800?
I havent tried anything yet, but will try the IR way.
Regards,
Gaurav Vadehra
hy gauravonline
i tried the programm SmartvCard from Symbianware on my 9210 and export all contacts as vcard. then i send this file by ir to my p800. when you open this file on your p800 it will ask you to import this contact. that`s my solution.
cheers rokey
Here's how i did mine... it took me less than 5 min...
Just sync your 9210 with your MICROSOFT OUTLOOK...
Then sync your P800 with your MICROSOFT OUTLOOK...
😉 simple.
