Nokia social upgrade 1.2.157
15 replies · 11,098 views · Started 27 October 2010
I just got a prompt on my N8 to upgrade Nokia Social. The only changes I can see are that the clock is now 24 hrs (as my phone is set) rather than 12 Hrs and the home page Widget now cycles through Facebook/Twitter updates
I had this earlier on.
You also might find that you can upload pics without using Pixelpipe now too.
Having the Nokia C7 for 3 days now, so far the phone has exceeded my expectations.😃
However, i accidentally removed the Social network application:frown: Is there any way of reinstalling it from other parties:con?
Many thanks for your help N8Owner. Reinstalled Social Network with success. The only thing i need now is the wallpapers which are missing because i did a factory restore which wiped the original wallpapers
You're welcome.
Which themes are you missing? If it is the Midnight ones Nokia released I had a similar problem. Go to Application manager> Installed apps and delete all midnight named themes. Then go to software update on the phone and they wil reinstall. However, if you mean some other themes please let us all know and I am sure we can fix it.
The themes are fine, its the wallpapers that are missing. These were originally installed in the Photo section that came with the phone.
Currently only have the Grass wallpaper which is default. did have a different one for the other two home screens as you scroll along.
Wallpapers are part of the themes. On the home screen click Option> Edit Home Screen>Options>Change Wall Paper> Select Default. This will then set the wallpaper to the theme setting.
I too have lost all the photos and videos that came pre-installed on the phone. Unless someone is kind enough to upload them we won't get them back.
I also don't know why my videos show up in the photo gallery. It's a bit stupid.
When i try to install the Social_1_2.sisx file on my C7, it keeps giving me "unable to install" error. can anyone help????
Currently i dont have any social app installed as i completed a hard reset. Ovi Store and Ovi Maps works fine but i cant get Social back. \
WildgooseUK wrote:Having the Nokia C7 for 3 days now, so far the phone has exceeded my expectations.😃
I need to know if your problem have been solved or not as I do the same mistake 😞
If it doesn't work on the PC, visit the link on your phone instead. And it will install. And Ovi Suite now has Nokia Social as an update available.
