SnaxMuppet wrote:
> Very clumsy and dated web browser
Agreed. They have already announced the web browser update which will add much of the functionality of Opera Mini 5 although I do agree that the phone should have launched with the new browser. Browser is expected before the end of the year.
The problem with this to me is that Nokia have had years to fix this issue but haven't done a single thing about it. I have had this issue going back to the N95 and been using Opera for the last year or so. They haven't innovated when they needed to - they even didn't bother to imitate.
Keyboards use is a joke - in landscape I can't use space bar to accept the suggested word. I have to either mistype the word on purpose to do that or use the right arrow and then press space bar. Why?
I can see why that might be so... I need to press the right arrow to indicate that I have accepted the word otherwise just pressing the space bar doesn't tell the phone that you have accepted the word suggestion. I much prefer the right arrow then space method.
The E71/72 both allow you to press space bar to accept words. It is the logical and intuitive way of selecting words. IMO.
> Emails apps crashes when using Mail for Exchange (Gmail) and IMAP accounts don't work on push basis - something I have been doing perfectly for years on my E71/E72
I didn't think you should be using the Mail for Exchange part for Gmail. Isn't there a separate Gmail section?Push email worked for me on IMAP during the little time it was working.
Nope, exchange is the best way to do it. It syncs your contacts, calendar and email all in one go. IMAP works for people that don't need all that functionality. And push IMAP doesn't work, the app will only update itself when you launch it, otherwise you have to set it to 5min or longer interval to get it working. It's a bug in the N8 which doesn't exist in previous versions. Another example of lack of QA. And the Symbian platform has always been limited to one MfE inbox so that means either I sync my work email or my personal Google account, which is way behind the competitors.
> I can schedule the time for my email retrieval but this sets the time for all my accounts. Why?
Don't know but it isn't a big deal for me.
To me it is an issue in that I don't want to really check my personal emails during working hours and conversely I don't want to sync my work emails on the weekends or evenings. Nokia's application doesn't allow me to do it, even though I can set-up multiple email accounts.
> Notification light doesn't work for emails, also worked on E71/E72
On the 5800 I never got a notification light for email AFAIR.
Again, very useful to have. The flashing light helps you to know a missed event without having to switch on the screen constantly to check. It works on the N8 but only for SMS and missed calls. Would it have been too difficult to enable it for email too? They have had this functionality in older phone like the E71/E72.
> Setting the lock-time to be longer leaves the screen on until it locks
Isn't that what it is supposed to do?
I should have explained myself better. We have two settings - 1. time delay before the screen goes off and 2. a setting when the key lock should engage. They are under separate settings in the phone. So, if I want to leave my phone unlocked for 60 minutes so I can quickly tap the screen to check for emails (because of the lack of flashing light) I can't currently do that because a bug is present whereby the screen doesn't switch off until the phone is locked. They are meant to be independent of each other.
I can certainly see what you are getting at but some of these issues are personal preference (predictive, email scheduling etc), some are easily fixable (search in music etc) and some are already due to be fixed (browser). I genuinely don't think it is quite as bad as you suggest for most people.
The problem is that most of these issues should have been addressed before launch. Either they were not properly tested, or someone at Nokia decided to launch the phone due to internal pressures hoping to fix them later. This for me is unacceptable either way. I have had too much of this with all my Nokia products and it has worn me down.
Considering the fact that Nokia are in serious trouble I would have expected them to make doubly sure to launch a product that set a new standard for the market and users. And instead of doing that, with years of experience behind them, they couldn't even match their competition.
As for Meego... if you follow the AAS podcasts then Rafe Blandford would have us believe that Symbian is still a mainstream OS for Nokia with Symbian being the OS for mid-tier and Meego for high end. I think he is right and it means that Symbian phones will continue to be developed for the foreseeable future and certainly for the lifespan of the N8/C7.
I have no doubt about that but Meego is where the make or break is for Nokia and their focus will be mainly on that platform for power users. And the hardware in the N8 will not support that OS.
As an example, the Qt based apps e.g. Ovi Store are about 3MB in size, and with a total memory capacity of 256MB RAM they have already shot themselves and us users in the foot. This same app written with the old AVKON would have been minuscule in comparison - kBs, maybe even kbs.
Like I said, it is farewell for now but not for ever. It depends on their next move. If the next product is robust and competes well with the rest of the market I will be back.
As a compliment to Nokia I will say they are very few manufacturers who build such great hardware. Except for Apple and maybe SE the rest are a pale comparison. I am buying a HTC and just look at the cheap plastic cover on the phone - it is penny pinching crap. But the phone does what I need it to do, and it does it now, not in 2 or 3 years time.
