so what does remote 60 do then + where can i find tv remote
2 replies · 1,830 views · Started 26 March 2003
as i said above people what is this remote 60 im trying to use it now but cant seem to work out what it does i think im connected as it says listening on it also wheres the tv remote thingy at and one more thing does any else have trouble using pc suite along with widcom drivers cos when i have both installed i get loads of error messages when i start the computer up so ive unistalled pc suite for now but i do want it on my system and to work properly
i get errors like broadproxy bla bla bla and capman or something like that and somting about task schecduler and ideas any one
Remote 60 allows you to control your mobile phone with your pc while ir remove let's you control a device such as a tv or cd player using your mobile phone(in other words it converts your phone to a universal remote control). The last one is currently on development and only beta testers have access on it...
Also about the problems you have, try to download the latest version of pc suite from nokia and also disable your firewall if you have one...
