I really would want to but is it free?
How can i login in AAS?
yes it's totaly free
AND FUN to be in 8)
JUST DO IT
Yes, just register, login and its all free 😃
I you were feeling really generous and want to support the site you could always but a T-Shirt 😉
and check here to get u'r free special edition background 8)
i can't view ur posted background nor can i download those application they re talkin bout? i would want 2, u know. im not registered and i cnt log in. wots d problem.
[quote="Alexus_sanzio"]i can't view ur posted background nor can i download those application they re talkin bout? i would want 2, u know. im not registered and i cnt log in. wots d problem.[/quote]
You cant see attachments if you are not registered.
Cant remember where the registration is. Try the buttons there on top of page.
Maybe that Login button does the job. 😃
Tnx. May i ask? Are you using your computer or your phone?
From PC, (With Opera (using phone as modem 😃 ))
And you have to have cookies enabled on the browser.
Try this link:
http://www.allaboutsymbian.com/phpBB2/profile.php?mode=register
That's the problem! I'm using my 7650 in here.. Got to go to my pc then. Tnx.
Also notice that you won't be able to see and/ download some stuff like attachments and web site links he you post through wap even he you are registered. But even without them it's worth registering... You won't regret it. Or you may regret it after getting addicted to it 😉
hey jyrik, how do you use the phone as a modem?
Just connect through BT with the BT Dialup networking profile.
Or start the modem app on 7650 and connect thru IR.
Its not easy to explain, so read the pdf manual on the CD that came with your phone.
