Bluetooth remote control
15 replies · 6,411 views · Started 27 March 2003
hey,
is there any software for the p800 that allows you to remote control your pc via bluetooth?
Sly[/b]
Remote control works fine trought GPRS (uses lots of bandwith though)
But I do not get it to work trough Bluetooth .
Syncrhronisation works fine trough Bluetooth, so the connection works fine. RC also says it is connected to the server (and the GPRS connection is not on) but there are no images coming trough.
Anyone who got it working ?
greetz
Riven :roll:
[quote="Sly"]hey,
Sly[/b][/quote]
Is there any update for this topic?
I think it might work if I plug the bluetooth LAN and install some client application on P800. I could not make it work by using Remote Control.
Has anyone tried it?
What I am actually looking for is that to use "Bluetooth Exchange Folder" of my PC from my P800. I use D-Link's DBT-120 and Bluetooth Software version-1.4.1 Build 6 and it offers "File Exchange" service/server" (second picture).
However, my P800 has the services in the picture 1. So I thought I might need to install some client application on my p800 :roll: .
Just found a solution. In fact, the remote control application works to control PC via bluetooth. 😃
I should have tried to connect PC from Remote control Client at my P800 after connecting PC and P800 by serial port.
But it is not exactly what I am looking for. Is there any application that can access to my PC's shared folder (for example: Bluetooth exchange folder) via bluetooth from P800 and then copy files from my PC folder to P800?
[quote="Tsogo"]What I am actually looking for is that to use "Bluetooth Exchange Folder" of my PC from my P800. I use D-Link's DBT-120 and Bluetooth Software version-1.4.1 Build 6 and it offers "File Exchange" service/server" (second picture).
However, my P800 has the services in the picture 1. So I thought I might need to install some client application on my p800 :roll: .[/quote]
What does the "Voice Gateway" do? I don't have that option when my P800 is connected....
[quote="Tigerdyr2"]This means that you can use your pc speakers and mic to make phone calls 😊 Just like the HCB-30[/quote]
Really!!! That sounds cool! Now why doesn't my laptop show this option when I connect my P800 (or any other phone for that matter)????
Delta 737! What is your bluetooth adapter? I am pretty new to DBT-120 and still experimenting this. It connects only a second or two then disconnects for Voice Gateway 😮
The manual says "The bluetooth audio gateway service allows this computer to use a remote bluetooth device's microphone and speakers as this computer's input and output devices. For example: if this computer has voice recognition capabilities, a Bluetooth headset might be used as the audio input device." and "The Audio Gateway Application allows a remote Bluetooth device to use this computer's microphone and speakers as the remote device's audio input and output devices."
I guess probably we need some application on P800 to use computer's speaker!
I have a Sitecom USB dongle... It came with "My Bluetooth Places", although it's still version 1.2.2.9 (or something like that). 1.3.x.x is already downloadble from their website, I just never bothered 😮ops: Perhaps that is what makes possible!?
Yeah. You should try the new version. For my case, the software that comes with my DBT-120 is quite different than the latest one I downloaded. (released on June 23rd 😃)
[quote="Tsogo"]It connects only a second or two then disconnects for Voice Gateway....I guess probably we need some application on P800 to use computer's speaker![/quote]
HERE is the step by step guide/solution to your matter.
The way voice gateway works for me is:
1) Make sure P800 bluetooth is set to discoverable.
2) My P800 receives a call.
3) I answer from the P800 via a tap on the OK button.
4) Once the call is connected, I double-click the "Voice Gateway" icon in the "My Bluetooth Places".
5) Viola! the P800 screen displays a message saying : "Sound transferred to headset". Then I continue my conversation on the PC or Laptop's mic & speakers.
Note: if I double-click the voice gateway icon before I tap P800's OK button, the call is disconnected.
Is this the way it's supposed to be?
FYI, I didn't change any configuration on my P800 or on the PC, except for installing the unadulterated, latest version of WIDCOMM v1.3.2.7 which I got from my OEM BT-usb's website.
