What is the best compression the phone can handle. I want to know the compression i can use when sending mp3 files to the phone, when using wav ringtones.
Post guide to make good quality ringtones from sources like mp3 and wav
do you mean to make the file smaller??
I just want to know the best 3650 can handle.
"Best" in terms of audio quality (= larger file, better audio)?
"Best" in terms of file size (= smaller file, worse audio)?
can u actauly even transfer mp3s and play them on the 3650?
Forget the mp3s. You can play them using a third party's program but you cannot get stereo. The best quality can be achieved by a wave pcm encoded file. The best for space saving can be achieved by a wave gsm encoded file (about 1/5 compression ratio). The best on both quality and space saving can be achieved by a wave adpcm encoded file(1/2 compression ratio). All the above can be also set as ringtones. All the codecs mentioned can be found on almost every windows pc...
does this phone hav loudspeaker for sound or do we hav to listen to it from headset or phone normal headspeaker?
[quote="fearce"]does this phone hav loudspeaker for sound or do we hav to listen to it from headset or phone normal headspeaker?[/quote]
Yes it has loudspeaker.......
Isn't it a fantastic mobile????
yeh...thnks
