Wishmaker wrote:My N8 has that issue but only on the upper side of the analogue clock. Everywhere else is fine. Should I tell Nokia about this?
it wouldnt hurt to tell nokia mate for sure more complaints the better
can you try this for me its quite weird but gets rid of the tint in places
download qt torch and install from ovi store -- download and select and use midnight silver theme -- open qt torch -- the background is supposed to be pure black as ive seen it on many n8s but may look brown/red/purple/ -- there are two touch buttons on the bottom of the screen that look like a grey/purple colour due to the silver midnight theme -- keep your eyes on these and press the qt torch on button -- as the screen light sup to full brightness you will as if by magic see your n8 turn the purple grey buttons at the bottom of the screen change them to the pure black they are suppose to be
the above mehod prooves to me something is wrong with some n8s screens , why does it show black as black oly on full brightness , is it a driver issue , is it a different screen , is it a faulty screen
the qt torch method ive listed to show the problem must be seen to be believed , not every n8 has this purple tint my gfriends doesnt and when i hold them next to each other i can see mine with the purple tint doesnt show colours as bright etc it shows the gradients of blacks and greys to be purple and its generally not as good to look at as her screen
you can also see it in the tron movies clips at the start , the skys and blackbackgrounds that are supposed to be pure black are actually like a brown colour due to the n8 messing up the gradients
i hope this can be fixed by software
i wen to lakeside and looked at many new n8s yesterday and because i know what iam looking for now every new n8 i looked at had this purple screen yet n8s from before december dont seem to have it although there are a few that still do have it even from before december
its weird stuff for sure and depending on what theme you use and what you do with your handset you may notice it more then others but fact is some screens on nokia n8 handsets are clearly not as good at displaying colours as other screens wether this is hardware or software i dont know but as stated above it looks like many new n8s have it going on
theres another thread here thats had nearly 2500 views in a few days mate
http://www.nokiausers.net/forum/nokia-n8/39462-i-think-nokia-using-two-different-types-screen-n8-maybe-c7.html
theres pictures and links galore in there
you can also right click the images in this thread , save the image and copy to your n8 , open photo viewer and test out the test image on your n8 screen , if you have the purple tint problem you will see it very obvious with this test picture , its the picture of the different colour squares or even the grey and white stripey one will show it up if you have it
