ICS calender on E7
2 replies · 2,810 views · Started 10 June 2011
I publiced my outlook calender to office.com, is it possible that I can use the publiced calender on my E7?
A example of the agenda link: webcals://calendars.office.microsoft.com/pubcalstorage/423hhzfz1239797/************-agenda.ics
This link, Calls a Microsoft page, the link has a direct association to Outlook, and will add the calendar automatically.
This specific link will not work for Your Nokia E7. I have many Calendars I could use in Exchange and it will not access those.
It has limited Public Folder Access and no ability to add a Public Folder from Google, either.
If you can find a App that will add that capability it would make me happy as well.
smcmanus wrote:This link, Calls a Microsoft page, the link has a direct association to Outlook, and will add the calendar automatically.
Hmm oke thanks.
Is there a other way to synchronisate with my outlook calendar? (without using exchange or cable)
