what kind if 128mb mmc
3 replies · 1,717 views · Started 20 June 2003
I just bought my 3650 and want to upgrade the memory on it what brand should i get? and where do i buy it? I live in Oregon,USA
My tip would be: try http://www.expansys.com/product.asp?code=MMC-128MB
Price is excellent (compared to norwegian prices)
Shipment is quick(FedEx)
My 128MB MMC is working PERFECTLY..
Good Luck!
RayGun
It's probably very hard to recommend the brand. They are all all probably made in the same factory somewhere in Taiwan and then badged differently. Seems to be the case with most electronics.
The differences between MMC's would be their warranty period...
It came with either 1, 3 or 5 years warranty...
Mine is a KINGSTON with a 5 year warranty...
😉 If your next phone will still be using MMC, i would highly recommend a longer period warranty MMC...
