Hi - my phone has recently stopped vibrating for calls. None of the profiles will and I have it turned on to vibrate for all settings.
I've been installing/uninstalling apps & games - could this have affected it?
is it more likely to be the motor?
will resetting the phone maybe clear it & make it vibrate again?
im sooo heartbroken if it is broken.......... 😞
Heard that either smart profiles or extended profiles cause this to happen.
Or a strong physical shock [😃]
I HAD THE SAME PROBLEM BUT IT SEEMED TO CLEAR ITSELF. MAKE SURE YOUR VIBRATING ALERT IS ON, INCOMING CALL ALERT IS RINGING AND THE VOLUME'S AT MAX FOR ALL PROFILES & THEN TEST IT. IF IT WORKS YOU CAN CHANGE THE SILENT,MEETING & PAGER PROFILES BACK. IF IT DOESN'T THEN THE VIBRATE MOTOR IS PROBABLY BROKEN.
Spent hours on this with my shinning new SX1 😊 tried everything!!! like unplugging the mmc/deleting profiles/reinstalling etc....
think I figured this one out.
If the phone is charging... it won't vibrate!
Duhhh!
Why seimens/nokia did this I don't know?
Well now you know 😉
Hope it helps.
/Gnuig
