Damn...my N3650 i dead...any ideas?
18 replies · 4,190 views · Started 01 October 2003
My N3650 just died...i was installing a program,and suddenly it stopped installing,the pgone dident response att all so i had to remove the battery.
and when i try to turn the phone on again it just lights upp and showing the blue nokia text...den stop there...
gah....and the "hold down pencil thing" dosent work.noting happends even then.
i have tryed to remove the sim and mmc card..but hell no...
is it anything else i can do?....?????
what is this junk....it seems like many people have that problem...the phone dies..
so i guess theres no hope now....i have to leave it in on repair ..
damn ...no hope....
well atleast i hope the upgrade the firmware on it to the newest....thing it was 2.50 or someting...
but i guess the phone is crappy even then ..
i newer gonna install apps or games on the pone memory again...when i get it back i gonna install everyting on the mmc card...then maby this wont happend again.
sorry my bad english...but im mad...my phone is dead...so i have reason to complain and spell bad.....yeah..or whatever...
i was installing space doubler......it was cracked...maby thats why it crashed...damn..no more cracks either...
what more apps/games can damage the phone?
You probably got a corrupted application. You may need to have your phone system rebuilt. If your phone is still under warranty (usually 1 year), then you may have it rebuilt for free. Otherwise, you'll have to pay for it.
Forgive me for asking at this frustrating time but why do you need Space Doubler on the 3650?
try turning the phone on. leave it on for 30 seconds. then remove the battery( do NOT turn the phone off before taking the battery out!) leave it for another 30 seconds & then try it. this might not work but it's the reset tip my operator gives me everytime i have a problem.
Theres your answer pal "it was cracked"
"why would you need space doubler on a 3650" - because it was free...
Sorry - no sympathy,
😡 keep using cracked software & you will just keep on developing problems. with any luck your phone will be rendered completely useless & then you will know why we told you not to use cracked software.
anyways. your costing developers money that they use to devolop more software. without that money the won't develop anything new so you are limiting your own phones capabilitys. 😡
Originally posted by Kirill
Cracked or not what is the point of using Space Doubler or Stacker on the 3650?
if he's cheap enough not to buy the application then he probably wouldn't buy a larger mmc. 😉
cracked software or not, fact is, the 3650 is a piece of shit. i just had my 3rd one die in 3 weeks. NEVER installed any programs besides at&t's jamdat bowling. i love the phone, but i need something that is reliable
You're right!
With 3650 the only softwares you'll need and is a must was a Task Manager and a SeleQ (for file managing).
It'll help to allow you install lots of application (into MMC) and still enable you to play GameBoy, MGS, 3D games and games that need more than 2MB free phone memory space to run.
And for illegal case, who'll know he might have having a bad MMC card that causes his problem. And is common that not all MMC were compatible or able to run smoothly on a Nokia 3650.
So next time do buy a MMC card with caution
I'm extremely happy with my 3650 together with a 128MB MMC card installed had already loaded with more than 150 applications/games/ebook, cracked or registered version , and still rock solid.
All this exclude hundreds of midi ringtones, some MP3, Wave, Music Video, Real media video and not to mention all my installation application/games softwares which stored on the phone too.
Well...don't ask me how I manage to did it as your case may be different...
I've had one since February. No faults. Works fine. Plenty of installed & uninstalled software. Firmware upgraded twice (just to get the latest & greatest).
i had a problem wit taskmaneger. it f****cked up my mmc but i repared it with the cardreader
good luck with youre phone illigal. its my worst nightmare
when my mmc was broke. i tottally freaked to so you dont have to be asshame about not spellig right or anything😊 😉
Don't worry, Illegal. I'm sure your phone will be fixed. About cracked applics, I'm currently using some and they are working perfectly. Just make sure you get them from reliable sources.
GRIM REAPER wrote:😡 keep using cracked software & you will just keep on developing problems. with any luck your phone will be rendered completely useless & then you will know why we told you not to use cracked software.
Jesus, why does everyone feel obligated to be all high and mighty on this subject. Are you telling me you have never downloaded a mp3? If you have, then its exactly the same principal, and i bet someone argue the toss and says its diferrent. It's not. Also no one needs a lecture, espcially when something's happened. That just winds that person up more.
Duffers,illegal got what he deserved and like i said before,you won't receive any support in the forums for problems caused using cracked applications.If you don't like it,feel free to leave.
GhostDog wrote:Duffers,illegal got what he deserved and like i said before,you won't receive any support in the forums for problems caused using cracked applications.If you don't like it,feel free to leave.
fair do's
