Problem with Photographer 2.0
5 replies · 1,790 views · Started 02 October 2003
Hi!
I have a problem with software Photographer version 2.0...
My phone is Nokia 3650, I install the software on my MMC card but when I try to execute the program a System Error message appare!!
Why this error ?
I must install this software on my telephone memory ?
The same problem with CameraFx software!!!!!!
TNX!
i had same problem wenn i installed on the MMC, but it works fine when you instal on the phone memory.
i had it installed on my mmc & i didn't have any problems. maybe you should contact the developer incase this is a simple bug.
Originally posted by Kirill
I think v 2.02 works off MMC. Do not quote me on this though.
OOPS... you are right kirill. i checked my installation log & it was v2.02 that i had. it worked fine of the mmc. 😃
Ok !!!! 😃
If I install Photographer 2.0 on my telephone memory it works!!!
A little problem when I try to change the Masks inside it's section.... A "Appl. closed cam KERN-EXEC 3" error appear!!!
This problem happens only whit "Mask"!
Why this ? Some resolution ?
regards
