Post tested MMC cards here,size brand and price.
Tested MMC cards
Twinmos, 128MB, PhP 2,488.00
Does not need formatting before you can start saving.
Originally posted by andrielle30
Twinmos, 128MB, PhP 2,488.00Does not need formatting before you can start saving.
dude, where'd you buy your 128mb MMC? i got mine quoted for 3k.
TIA
PQI
128MB
Rs 2800/- ( Approx. 64$ )
Delhi ( India )
128mb Dane elect: 59 euro
greetzzz
TEC 128 MMC
�32
PNY Technologies 128MB
2 Year Manufacturers Warranty �34.99
Rob.
Originally posted by ssaloon
dude, where'd you buy your 128mb MMC? i got mine quoted for 3k.TIA
Got my Twinmos 128MB for only Php2,250 (around US$40) and a 6 in 1 card reader for only Php1,300 (about US$23).
TEC 256MB around 80 USD from taiwan
a note also, all TEC MMC cards, 128/256/512MB work with n6600
microsim
128mb
$45
India
transcend
128mb
$49
India
In cyberzone in megamall. I can't remember the computer shop. It has 6mos. warranty.
Where did you buy your memory card and card reader? Thanks.
TEC 512MB for �100 from the US.Works fine.
LEXAR Media Multimedia Card
128 MB
Price: about 150.000.000TL's. Works great. No format needed...
Both it from Hytech, their store is located in New Manila, QC, you have to order though wait for 3-4 days because they don't have on stock.
is the store located near the gilmore-aurora intersection? the one with the computer shops all around? TIA
Hama-256MB, around 90EUR, 2 Y warranty
128 MB
High Speed Media (Works like a Charm)
�20 (Got it from Saudi, thats why it's cheap) and the phone costs �285 Sim-Free.
Infineon 128M Works great!
Price: Rp.340,000 (approx $40)
Impact MMC card. from Dixions (UK) 128mb �40 simple and just round the corner
mine is apacer 128mb mmc got it for around $45
Any one bought a 256mb/512mb/1GB MMC card in the UK which works problem free with the 6600? How much and where from?
Saf
Kingmax 256MB MMC card from eBuyer. Cost �41.99 + VAT in Nov 2003, and it works fine in my 6600.
Kingmax 128 Mb
S$89
from sim lim square (where else in Singapore 😊 )
D
Originally posted by ktorpilHow did you get your card to work in your 6600? It doesn't seem to fit properly in mine as it's slightly thicker than the 32MB card you get packaged with the phone. Is there some special way to place it in? 😞
128 MBPrice: about 150.000.000TL's. Works great. No format needed...
Prob coz its not a Multimedia card, the SecureData cards look similar but dont fit.
U need a Multimedia (MMC) not a SecureData (SD)
Mine fits perfectly and it is not thicker than the original 32MB MMC. Maybe what you bought was a different type of card from the same manufacturer...
so a lexar SD/MMC secure data card will not work on n660? or any other secure data card.? will this fit exactly.. they look pysically the same.
SD cards don't work with the 6600,only MMC,read the FAQs and Manuals.
