6600 codes
107 replies · 254,135 views · Started 23 March 2004
Ok, ok ... but my site is no warez Site!!
On my site are only links to sites that may have warez as a content!
Alls Codes that I know for 6600
*#06# Serial Number/IMEI indicates
*#0000# SW version (e.g. V3.42.1, 16-10-03, NHL-10)
*#2820# Bluetooth (BT) device address
xx# Directory quick access (xx = storage location and afterwards lozenge e.g. 24 #)
On/Off key -short pressing for menu for switching between profiles
Menu key - Long pressing for "task manager" - switching between active programs (with "C" key programs can be terminated.)
Menu quick access - Over in the menu e.g. to point 3.1 arrive simply 31 enter (if the third symbol a file is opened is for these and then in it started the first Programm/Icon).
No Autostart - When switching the phone on up to the pin inquiry press the whole time the "ABC" key (pen) - this is to ignore the autoinitialization programs (and the MMC programs) - "safeboot".
12345 ... is according to be the standard Nokia nokia-securitycode.
0000 ... is according to be standard PIN2 at Vodafone (germany)
Caution - starting from here the codes are "dangerous"
*#7370925538#
*#Res0Wallet#
... is to delete the code around the "wallet"
Input like normal telephone number (not in wallet code inquiry windows).
NOTE! Afterwards the "wallet" is empty, can again be put on however with new code.
*#7780# - Reset to original settings
NOTE! Afterwards various "attitudes" are away - among other things these:
Points of entrance (Provider dependent points of entrance and attitudes)
Bluetooth attitudes
Favorite
Allocation of the two keys (beside Navi keys) in the main menue
Profiles are "neglected" (as with distribution) - still there however new bell tones, etc. are...
SMS/MMS/E Mail attitudes
Logos and spielstaende (allegedly) also deleted...
Programs, calendars and contacts, etc. not changed...
*#7370# - Soft format - resets all the telefone Memory (like Formatting a disk 😊
NOTE! Battery should be full up to at least 75%, do not accomplish during the procedure under any circumstances ! The procedure takes some minutes (approx. 3-4)
Green, * 3 - Hard format: If the Mobile (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET.
Proceeding: Equipment switch off, keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears...
Sorry for the bad english - but I have done this with a translation programm ...
those are really really helpfull codes
i always wanted a sticky😞
by the way what is your website?
Ismail,his website contains links to warez.It can't be posted here or shared via any of AAS services(PM,E-Mail).
Originally posted by Ismail
heard ya loud and clear😃
Ismail, BTW, you we're right about the HDR-1 Music player. The power connector slightly differs and as such it won't work.
There, I admitted it. You were right 😃
But I'm really disappointed of the phone not being stereo. I'm gonna sell it and buy a P900.
BECAREFULL!!!! When you use the GREEN * 3 formatting method there's no confirmation AT ALL!!! I tell you 'cos I formated mine yesterday by mistake 😞
[thanks mate you are a life saver. i been having lotts of problums with application manager butt when i try some of your codes problum sorted nice one
i've installed qOffice to my n6600 -hoping to be able to make it work although it is for UIQ- and now i continiously getting the "App. Closed AppArcSreverThread" message. I tried the code you gave to safeboot, but it still autostarts the application and it crashes the os. I'm now able to open the phone just by removing the MMC. Is there an other way to safeboot?
numeric wrote:Ok, ok ... but my site is no warez Site!!
*#7370925538#
*#Res0Wallet#
Bluetooth attitudes
Favorite
can i have the register code for spy call?
wugui wrote:can i have the register code for spy call?
No warez,this is your first and last warning,next time you will be banned.
FYI- I was having some problems caused by software incompatibilities with my brand new 6600, so I decided to try the hard reset procedure. It worked well. When the process completed I was forced to remove the SIM chip and MMC due to errors on bootup. I powered up again without them installed. When I received the message to insert a SIM, I powered off, inserted the SIM and MMC, and powered up again. It works perfectly now. All original carrier-specific settings are intact, and the phone is fine. THANKS for the codes!
arcrut wrote:D u know the code to restart the phone without pressing the on n off button?
You can use FExplorer to do that
Unregistered AL wrote:[thanks mate you are a life saver. i been having lotts of problums with application manager butt when i try some of your codes problum sorted nice one
Dear what problem you had with applications. As i am also facing one. What exactly have you done to restore orignal applications
>NHL-X isn't actually a software revision number is it? It's written on my device a few lines below the IMEI and it's part of the FCC (Find Catch and Control) number. Has anyone seen a 3.42.1 go to 4.09.1 AND change to NHL-10 (unless all 6600's are NHL-10)
>Is it just me or have there been no nokia updates since feb for this device
>Sweet! That should just be an application. Can't plug it into my contacts/address book (it tries to dial) anyone know a way around that?
>This says nothing in/for that SIM address and if I enter 1 it autocompletes to 123. I tried some higher ups for my card, but no luck. Anyone get this working on MMC?
>Anyone verify this works?
*#7370925538#
*#Res0Wallet#
Bluetooth attitudes
Favorite
>phone name changes (bluetooth attitude)
This is the same as Menu>Tools>Settings>Phone>General>Orig. phone settings (Right ppl?)
*#7370# - Soft format - resets >all the telefone Memory (like Formatting a disk 😊
>Didn't reset all my phone memory
>Did this: Held Green Key and Pushed Power Off. Then (Holding Green key still), pushed and held "*" and "3" and then held power on. Released power and green and got to formatting. You know you did this right when formatting appears and it wipes the screen from left to right in black (slowly).
>Since I had the same firmware after resetting I'm wondering if there's another code that goes to manufacturer default or if a firmware update somehow overwrites the rom instead of strapping in. Anyone?
Thanks for the codes again!
fexplorer is like a windows explorer of our computer, you can see all your files and folders just like in the window explorer ok? and in this fexplorer you can also set your personal operator logo... check it out download one and try... 😊
deathmonger wrote:BECAREFULL!!!! When you use the GREEN * 3 formatting method there's no confirmation AT ALL!!! I tell you 'cos I formated mine yesterday by mistake 😞
[FONT=Tahoma]by mistake?!?!?!?! took me 3 attempts to turn phone on with all those buttons pressed lol :redface: [/FONT]
[QUOTE=JasonT>NHL-X isn't actually a software revision number is it? It's written on my device a few lines below the IMEI and it's part of the FCC (Find Catch and Control) number. Has anyone seen a 3.42.1 go to 4.09.1 AND change to NHL-10 (unless all 6600's are NHL-10)[/QUOTE]All 6600's are NHL-10's regardless of the firmware revision. NHL-10 is Nokia's product type code for the 6600.
N/A wrote:[QUOTE=JasonT>NHL-X isn't actually a software revision number is it? It's written on my device a few lines below the IMEI and it's part of the FCC (Find Catch and Control) number. Has anyone seen a 3.42.1 go to 4.09.1 AND change to NHL-10 (unless all 6600's are NHL-10)
All 6600's are NHL-10's regardless of the firmware revision. NHL-10 is Nokia's product type code for the 6600.[/QUOTE]
Thanks, I guessed that when I saw the 3650 was NHL-8 hard coded. Anyone got codes for memcard dialing yet?
how do you enter the wallt reset code ive got the *#73780925538#*# but how do i do res0wallet
thanx
a dude in need
hello there. Unfortunately i have forgotten my nokia 6600 Wallet code. i tried your mentioned code but it is not working. when i enter *#7370925538# it opens a lock code box. when i enter CODE is says CODE Error!.. plz help me reguarding to this . :frown: :?
