Hello!
First test version.... http://www.redshift.hu/stewe/LegacyTest1.sis
The next test versions should be a single .app, I'll post it here (since the data files are pdb ones - probably they won't be modified).
Could you please check it ?
Info:
- as I have mentioned, memory problems on 9210 (a reset could help)
- The starting process is very slow... I don't think I can improve it, sorry.
- Don't forget to get more members in the first city, because you start with only 1 character (random type)
- If you have a mood, please check David Eaton's review... it's for Palm, but the game is the same: http://www.redshift.hu/legacyreview/legacy.htm
- the help is for Palm/Ppc version, I'll work on this
Until that, quick help for keys:
GENERAL KEYS: Enter works as "Yes", ESC - "No" when you see a question. Enter and Space can select an item from a list, ESC can close the same list. There are buttons in the game, with highlighted character in their title (as shortcut).
GAME SCREEN KEYS:
- Up/Down: forward/back. Left/Right: turn. Ctrl-(left/right): slide
- Enter-Melee attack/Hit something
- C-Cast, then TAB-change spell category, arrows - select a spell, then C or space or enter - cast that spell
- 1..4: select a member in the party, pressing again: enter the member's inventory.
- P - pick up
- M - full-screen map (ESC closes it)
- Space: enter a door, use something, open a barrel's/vase's inventory, ...
- E: end attack turn, probably I should show a blinkink "*E*nd of turn" at the right/top corner of the game screen
INVENTORY: you can see the shortcuts...
OTHER SCREENS: shortcuts, almost everywhere
Please post here the results. You can send me your IMEI for the regcode, however, please wait for until the game doesn't let you advance more (level 6), or blocks you (after killing N'Gora - probably more hours play).
The next test version can be in 1-2 days, I have several, very small issues - for example:
- X - immeditely return to main screen from game screen (for saving...)
- Arrows in the inventory item list - to see if there are more items than the currently visible ones
- Communicator-specific Help text
AND! You can download the first downloadable, additional map for the game: Morah's plan. It should be copied to the Legacy directory on your device (\system\apps\Legacy\). Now if you go to the Global Teleport in the first city, then you should see a new teleport target: "Morah's Plan". This map is optimized for a party with level 2-4 characters.
download url: http://www.redshift.hu/Legacymap/Morah.pdb
Later, I can give you the expansion pack... it's connected to the 3rd city, Grendelmoore, and optimized for level 15+ characters.
And... sorry for my English! 😊
Stewe
