Hi
I created a wins udeb sis file with the series 60 v20 sdk.
how do I install it via the emulator ? ( emulate the installation )
there is no install option on the menu ...
thanks
series 60 emulator sis installation
Hi there,
If you have a .sis file, place this file in the
%EPOCROOT%\Epoc32\wins\c\nokia\installs directory.
Now when you invoke the emulator, the .sis application appears in the Communications -> Application Manager option. This has an install option.
I think this should solve your problem.
Regards,
Ravi
thanks
when going to Communications I see two options :
bluetooth and infra red.
no Application Manager .any suggestions ?
Ravi Nathwani wrote:Hi there,If you have a .sis file, place this file in the
%EPOCROOT%\Epoc32\wins\c\nokia\installs directory.Now when you invoke the emulator, the .sis application appears in the Communications -> Application Manager option. This has an install option.
I think this should solve your problem.Regards,
Ravi
Hey,
There is an Application Controller in the Tools folder of the emulator's Application Picker. I don't know if this is it but you can give it a try.
Regards, Aljaz
