This is the logo of my operator in Greece.
I read that the size of the operatot logo pics must be 97x25 pixel.How can i change the size to be able to use it??Pls can anyone help me?
How can i change the size...
if u are using windows xp on your pc, just double click the image from the folder to go in to the built in image editor, and then select the option "image" and "resize" and just put what number of pixels you want, the picture to be.
How about this?
Unfortunately the proportions don't allow occupying the whole available width..
If you need more help, you know where to find me... 😉
Thanks for the reply mate..
[quote="petran"]How about this?
If you need more help, you know where to find me... 😉[/quote]
egrapses megale thanks 😃
Krima mono pou den pairnei animated gif arxeia ayto tha htane poly wraio
Here's the second... although it is way too small due to its frame.
i'm cutting away those extra white space for the 1st logo
http://arofanatics.com/members/cwleo8888/7650/image03.jpg
shame these wernt on here 3 weeks ago really as i was in greece on roaming to my suprise only found there were 3 greek mobile companies ... Panafon and Telestet being about the same signal rating but GR VODA far surpassing them in Halkidiki ... Would have been good to have had one for each on my phone rather than the normal black text...
Doh ! im wafling now aint i ..
[quote="cwleo8888"]i'm cutting away those extra white space for the 1st logo
http://arofanatics.com/members/cwleo8888/7650/image03.jpg[/quote]
coooooollllll 😃
brilliant..
thanks
