hi all
is there a simple way to print log messages (like printf or something ) while running a C++ application on an emulator ?
if there is , how can I use it ?
thanks
hi all
thanks
Hey,
You can use User::InfoPrint() just be careful this doesn't work on device. If you want a method that works on device as well try CEikonEnv::AlertWin(). See the SDK topics Class CEikonEnv and Class User for more information on these methods.
Regards, Aljaz
If you are running the app on the development platform (i.e. VC), then RDebug::Print (or something like that) will print a message to the standard debug window.
thanks a lot
cmatthee wrote:If you are running the app on the development platform (i.e. VC), then RDebug::Print (or something like that) will print a message to the standard debug window.
