Problems and Recommendations
41 replies · 12,320 views · Started 28 August 2004
Hello everyone!!
A few days ago I received my Sendo X! The wait is finally over! I've been monitoring the progress of this phone for quite a while now. My desire for this phone goes way back, when the phone was code-named Z100 and it was about to be released as the first device on the market to run Microsoft's Smartphone 2002 software.
I bought the phone from nomatica.com for 436 euros including a crappy black case. I thought the case was specifically made for X but it's not. You have to open the case and take the phone out every time you need to use it! The phone was sent from France and it took 5 working days to get it, but hey, I just live in a small island somewhere in Greece (Rhodes) so no surprises there. It should take a couple days to reach other major european destinations. And yes, you guessed right, everything is in French; manual, phone language, etc etc, but I had already downloaded the english version of the manual and it's easy to switch to english menus on the phone, so no problem really.
The following is a list of problems that Im currently facing with my Sendo X. There are also some thoughts for future upgrades!
When i answer a call, phone keeps vibrating for a second or two!
There's no messages and contacts manager included in the software! Hopefully a new version of the famous Oxygen Manager supporting the X will be out soon(www.oxygensoftware.com)!
Surprisingly enough there's no option to sync notes! You can sync just about anything in outlook except the Notes! How could they miss something like that? How weird...
No vibration alert for incoming messages!
No repeat option for alarm! Problem solved with Handy Clock(http://my-symbian.com/7650/applications/applications.php?fldAuto=37&faq=2) You can set up to 8 clock alarms at the same time and it supports 5 types of alarms: once next 24 hoursm, daily, weekly and workdays!
There's a bug with word countdown when Im writing an SMS message. In the beggining I just thought that there wasnt such an option but later I noticed that if I open up the options menu and then cancel it will appear for just a fraction of a second. So it is there, it just wont show... at least on my phone!
No option for full size pics in the photo view app
No mp3 support for ringtones!!
Gif animation is horrible and there's no repeat option!
Correct me if Im wrong but I think that there's no option for auto keypad lock!! How could they miss that?
Sometimes when I unlock the phone backlight takes time to be activated!
Voicemail wont change! I go to the tools > Call voicemail, I change the number, I press the 1 from the Now! screen - which is the speed dial for voicemail and it calls the number it was originally assigned on the phone!
No option to save messages on the memory card!
I wish the Now! screen was a bit more flexible! For example, since I dont check emails from my phone I'd like to remove the "Check e-mail" option from the messages plug-in and i'd rather have received, dialed and missed calls in the "Call record" plug-in. Also I'd rather have an option to have the events displayed on the calendar plug-in instead of the appointments!
Sendo has done a wondewrful job to combine all these great softwares and technologies together but I think that the company should pay more attention on how to make things simpler and more practical. For example, people want to send a message as quick as possible. Right now, the quickest way to write a message requires me to go through at least 4 menus. Why dont they use the edit and voice keys as shortcut keys in the Now! screen? There should be an option in the Now! screen to assign shortcuts for those two buttons. Edit key could be used to quickly write a new message, while voice key could be used to quickly make a note in the voice recorder. Most of the time, when people make a note in the voice recorder is because they want to quickly record something so that they don�t forget and because they have no time to just write it down. If they have to go through so many menus to activate the voice recorder, they just wont use it really. It's just not practical. It would only be useful if the user could press the voice key and make a note and be saved automatically.I really hope they take this recommendation very seriously!! I feel like with my old phone I could do my everyday tasks much quicker; press left and write a new message, press right and check my calendar, press down and view my contacts... as simple as that!!!
I have already emailed my problems and recommendations to [email][email protected][/email] as requested before, and I also hope that plinkykev will help me out here and forward these notes to Sendo as an insider 🙄
I am a bit concerned about the problems that Im currently experiencing with my phone but the fact that a new firmware is already under development and that Sendo pays so much attention on customer feedback is very encouraging, and I must say that I feel confident that the best is about to get even better 😉
I just wish someone could come up with a solution on how to add the greek dictionary on the phone! Don't care about greek menus, I only need the T9 files to be installed. Anybody? No? I thought so :frown:
first of all, why make a new topic, you could have easily added this to another topic with bugs. Let's keep the forum easy to read shall we 😉
=> solved in firmware
=> i don't know what you mean by contactsmanager
=> mail to nieuwemobiel
=> true, solved in firmware
=> you can set the alarm to repeat every day or every week. At least i can
=> there is no countdown, that's true. But you can't call it a bug. A bug is something that doesn't work. A countdown should be added in the new firmware.
=>NOT TRUE ! just open foto album and open a picture. Next choose full screen in the options.
=>why use mp3 if wav works. Just convert the mp3 to a wav file and put it in
c:\nokia\sounds\digital. That does the trick 😊
=>gif animation? can you send an example of a gif animation and how to open it? thanks
=>auto keypad lock is missing yes, but just use the left soft button and then * and you will have your phone lock. I never had auto lock and i think i'd find it pretty annoying.
=>when the phone is locked and you push the left soft button, first only the keypad will be light-activated, then when you push * the screen will be activated as well.
This is so that when you use the phone in your pocket, the screen wouldn't turn on everytime, effecting a lot of unnessecary battery loss.
=> i changed the number and pushed nr 1, no problem at all. go to menu, tools, voicemail, then option and change number. save it and try again. It should work. I have a newer firmware and it works, so don't worry.
=> the phone memory is big enough to save all the messages. I don't know how many megabytes of SMS you want to save...
=> you can't really call this a bug. There are more serious bugs at hand in this moment. Later, options like yours could be taken care of in a newer firmware.
=> the problems you stated are nothing compared to the more serious bugs people encounter with the sendo phone. Try playing a big movie in realone or smartmovie without stuttering image. Try playing WB-amr files on your phone, or listening to amr files just that. even when sometimes somebody calls me the sound cracks like hell. THOSE are real problems. Most of what you mention are practical gadgets. None the less, they could be taken care of in future firmwares.
SPEEDMAN wrote:first of all, why make a new topic, you could have easily added this to another topic with bugs. Let's keep the forum easy to read shall we 😉
to edit, store and synchronize phone data on a PC. Have a look at Oxygen Manager and Nokia Phone editor!!
I dont think you can! There's nothing mentioned on the manual either. Maybe on the new firmware that you already have...
it is a bug because THERE IS a word countdown but it wont be displayed while you type the message. Try to press the options menu and then cancel, you'll notice that the countdown will show up just for a fraction of a second as soon as the menu pops out!
it is true! Im not talking about full screen, but full image size!
I'll tell you why not. Because I've just converted a 51,5KB mp3 to wav using nero tools and it came up with a whopping 1,10 MB file!!!
pass me your email if you like, and I'll send you an animated gif file!!
Most phones have autolock option and it is very useful because buttons might be pressed by accidently, for example, while you carry your phone in your pocket or in a bag.
You are right, I am aware of that, but still backlight takes time to be activated after I unlock the phone
Been there, done that! Hopefully the new firmware addresses this issue!
I want to save lots and lots of MBs!! And I'd rather save the phone's memory for other stuff! Why can't I just have the option? Don't think it's that hard really 😊
Im not calling this a bug. Im clearly making a recommendation here! the title of the topic is "problems AND recommendations"!
The phone is partly used for business critical applications. For me, it is a business tool! I can't stress out enough how crusial is for me to be able to keep in touch, keep records, make notes tasks and appointments as quickly and efficiently as possible! All these futures such as mp3 players cameras and camcorders come second for me. I dont wanna downplay the importance of the other problems that we are experiencing with some other applications but dont tell me that the problems I stated are nothing. And again, this is not a problem, I never said it was. Im just making some recommendations for future upgrades and I hope Sendo will take this recommendation into consideration very seriously!!
=> use outlook, the contacts on outlook are the contacts on your phone. That way you can add adress, phone, everything you like.
=> yes you can, i don't remember how i did it last time, but it does work. Maybe if you make an appointment and add an alarm to it. Then you CAN make it repeat itself weekly or dayly.
=> the fraction you see is because when you are planning to send it, it counts if it isn't 2 sms in stead of 1. If it is more, it will say on the top how many you are and ask if you still want to send it.
=> i don't know what you mean, if you want full image size, then use zoom. You can zoom untill you see the pixels of the photo.
==>> try using a little less quality, 44khz and a high stereo isn't really needed. Wav is a little bigger, but what you said is absurd.try using power mp3 WMA converter. U can choose wav there 😊
it is highly unlikely that those two buttons would be pressed in that order with the right timing, causing the lock to open.
==> then accept it 😉
==> i don't know why, but i'm almost certain this option will never be added. Putting contacts on your mem card also won't be possible. This has nothing to do with sendo but with the symbian 60 phone system of nokia.
The phone is partly used for business critical applications. For me, it is a business tool! I can't stress out enough how crusial is for me to be able to keep in touch, keep records, make notes tasks and appointments as quickly and efficiently as possible! All these futures such as mp3 players cameras and camcorders come second for me. I dont wanna downplay the importance of the other problems that we are experiencing with some other applications but dont tell me that the problems I stated are nothing. And again, this is not a problem, I never said it was. Im just making some recommendations for future upgrades and I hope Sendo will take this recommendation into consideration very seriously!![/QUOTE]
Personally i think you bought the wrong phone. A P900 or a later P910 would have done the trick for you. That's a REAL business phone.
[QUOTE=SPEEDMAN]to edit, store and synchronize phone data on a PC. Have a look at Oxygen Manager and Nokia Phone editor!!
=>use outlook, the contacts on outlook are the contacts on your phone. That way you can add adress, phone, everything you like.
It's not the same; I can't write/delete messages or assign names to groups etc etc. I know I can do all that from the phone ofcourse, but it's way faster to do these tasks from my computer since my phone is always connected to it when Im home!
=>yes you can, i don't remember how i did it last time, but it does work. Maybe if you make an appointment and add an alarm to it. Then you CAN make it repeat itself weekly or dayly.
Well it doesn't matter really, problem solved with handy clock 😊
No that's not what I mean! Im not talking about this notice. I can really view how many words are left, but just for a second, then it disappears. Anyways, hopefully prob will be solved in the next firmware release.
=>it is highly unlikely that those two buttons would be pressed in that order with the right timing, causing the lock to open.
You didn't understand my example. auto lock is used so that if you forget to lock the phone it automatically locks so that it wont make any accidental calls!!
"You are right, I am aware of that, but still backlight takes time to be activated after I unlock the phone"
=> then accept it 😉
I'm already accepting it, but I hope they'll come up with a solution soon 😊
I think SX1 can
=>Personally i think you bought the wrong phone. A P900 or a later P910 would have done the trick for you. That's a REAL business phone.
I aint gonna spend 800 euros to buy a brick :tongue: the X does anything that P800 and P900 does and it has nothing to be jealous of from these models - apart from the screen ofcourse, but hey, that's what makes it a brick really! I dont want you people to think that I don't like this phone. I bought the Sendo X just because I believe it's the best phone out there! I am very happy with my purchase. Im just writing down some of my problems and thoughts to share them with you. That's all 😊
I have compered my opinion with a lot of my Italian friends that have got a Sendo x ,and I can said that the most important BUG is that sometimes ,when my signal is on top ( Wind ) , i can't receive a telephon call and I can only restart my Sendo to receive it !!!
My software version is: x 1.22.8.1
14 Jun 04
P.S. sorry for my English ,I hope you can understand me.
Best Regards .
Stefano.
casatiel wrote:I have compered my opinion with a lot of my Italian friends that have got a Sendo x ,and I can said that the most important BUG is that sometimes ,when my signal is on top ( Wind ) , i can't receive a telephon call and I can only restart my Sendo to receive it !!!
14 Jun 04
Best Regards .
Stefano.
Same thing also for me. card omnitel
And when will we be participating in Sendo's successful resolution of its firmware?
Thanks in advance for any insights!
OT question, just thought I'd post here since you guys avtually have one. Does the X feel cheap, i.e. sqeaky plastic? Or would you say that it is solid?
IRONLUNG wrote:OT question, just thought I'd post here since you guys avtually have one. Does the X feel cheap, i.e. sqeaky plastic? Or would you say that it is solid?
It definitely doesnt feels cheap! It has a very professional and elegant look and it feels very solid! Oh, and I love that carbon fiber stylish finish 😎
TELSON wrote:It definitely doesnt feels cheap! It has a very professional and elegant look and it feels very solid! Oh, and I love that carbon fiber stylish finish 😎
does anyones phone start to flash on and off when you get an incoming call, mine does, it never used to and my call divert keeps appearing and dissapearing strange and the phone freezes alot so have to turn on and off
My phone also flashes when I get a call, but it wont come up with any call divert msgs! I suggest you format you phone by pressing and holding the button 5 while switching on the phone. Be careful though coz all your data WILL BE LOST!!! So make sure you make a back up first. That might solve your problem temporarely... SPEEDMAN claims that all these issues regarding phone reception and incoming calls are solved in the new beta firmware, so stay tuned!!
Hope that helps!
u make me laugh hahaha say again profesional hahaha i sold mine cuz of that it feals very very cheap like they bild it in they'r own basement,even the person i sold it told me hes gonna sell it on ebay cuz of the cheap build,feels very solid hahahaha
Come on nutzu!! It's not a secret anymore! We all know you wish you had a Sendo X. You systematically trying to convince yourself that X is not the best phone out there! But it aint gonna work!! Dont go so hard on yourself! You don't have to be so jealous! Dont give up hope!! Maybe one day you might be lucky enough to hold one as well! Just be a good boy and maybe Santa will get you one for Xmas 😊
Nutzu wrote:u make me laugh hahaha say again profesional hahaha i sold mine cuz of that it feals very very cheap like they bild it in they'r own basement,even the person i sold it told me hes gonna sell it on ebay cuz of the cheap build,feels very solid hahahaha
I think its very good quality. Have you used the 6600????!!!
After sending the list with my probs and recommendations to '[email protected]' I received today this email:
Dear Sendo X users,
I would like to thank all of you for helping Sendo in fixing all the bugs
you are encountering in your phone. We from www.pdatotaal.nl and
www.nieuwemobiel.nl are helping Sendo in all the possible ways of
showing them your mails and lists with bugs. The most bugs we had
were the same in their content. These bugs will be fixed as soon as
possible
Sendo is working hard in making a new software version and upgrade
for you phone. New Beta versions are already tested by several users
and our organisations. It looks good and in the upcoming weeks we
will see the new software version for you all.
In this new version several bugs are fixed and the theme change option
is an extra. It will also be possible to add new made themes to the
phone. The themes are made by a program which can be downloaded
in the upcoming weeks from the Sendo site.
The main bug that shall be fixed is the "bad sound during calling"-bug.
Next to that the phone will be must faster in the menu and the
coverage of the phone on several networks shall also be better.
Please, if you have new bugs let me know and we will send them to
Sendo in the upcoming days.
Yours faithfully,
Marc Rutten
Content supervisor www.nieuwemobiel.nl
TELSON wrote:Come on nutzu!! It's not a secret anymore! We all know you wish you had a Sendo X. You systematically trying to convince yourself that X is not the best phone out there! But it aint gonna work!! Dont go so hard on yourself! You don't have to be so jealous! Dont give up hope!! Maybe one day you might be lucky enough to hold one as well! Just be a good boy and maybe Santa will get you one for Xmas 😊
hahaha i'm in howard forums too, and there i tried to make and trade with that shity x so go there search this nick name ''p-Ostal'' and ask him about the sendo x if he like it cuz he didn't whant to trade when he saw whant shity made is x my nick name there is OLyP,http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=5713570450&ssPageName=STRK:MEUS:IT and that was my listing on ebay and i sold it to the last bider cuz i whant to get rid of it and if u don't belive send me a mesage from ebay and i'm gonna paste here to show u that is my nickname there(i hate when this kids come with this arguments to me hahahaha) 😊
mart_is_good wrote:I think its very good quality. Have you used the 6600????!!!
yeap but now i have n7610
Nutzu wrote:yeap but now i have n7610
only probs i have with the x is... call divert keeps dissapearing, and sometimes phone freezes, ive never had probs with loud noises when making a call, and the buttons flash when call arrives thats it.. i love my x :icon14: 😊
hey nutzu, i have a new firmware and all the things work, have fun with your mono sound 7610 with abnormal keys. I sent the firmware to some italians and now NONE of them have problems anymore.
again a wave to nutzu, the-hopeless-trying-to-tell-everybody-to-not-buy-the-sendo-because-his-didn't-work-7610user :ciao:
SPEEDMAN wrote:hey nutzu, i have a new firmware and all the things work, have fun with your mono sound 7610 with abnormal keys. I sent the firmware to some italians and now NONE of them have problems anymore.
Quite Speedman quite...
for now they says after 2 days that seems reception bug be clear (I hope!), speed men� navigation is improved, more clear audio, but then other little and medium bugs still there are (screen flickering, miss countdown numbers characters writing SMS)...
I hope that official first firmware resolve other little and medium bugs too and reception works perfect! After, Sendo must improved video performance (SmartMovie and Mobiclip anyone?) and free more RAM for applications...
Matthia wrote:Quite Speedman quite...
good one matthia!!
matthia, all of that will be solved by sendo.
i Must say that the bug you mention of mobiclip or smartmovie is NOT a sendo bug.
Sendo has sent some mobiles and development kits to those people to fix all the problems. It's not to sendo to fix applications they didn't even make. Sendo has all the capabilities for smartmovie and mobiclip to work fine, but the applications aren't compatible.
that's why sendo sent the X's to them to fix their applications.
we just have to wait ... 😉
haha abnormal keys??where??for me are normal for siemens sx1 are abnormal and yes is true is mono but i'm not listening to mp3 player is useless for me,and i'm not saying don't buy the x,i just told u my experience with it :tongue: 😃 :icon13:
