My 6630 develops another new bug :(
2 replies · 2,125 views · Started 11 February 2005
My 6630's gallery application now refuses to aknowledge that I have any images or video clips stored on my phone. The image manager app, with the 3D gui works fine. Any ideas?
I thought it might be because my RS DV MMC (Designed to improve mbattery life, so why is mine only just over 24 hours stand by?) was nearly full so I removed a truck load of data, but still no luck. Soon after the phone developed (for the third time) the restarting bug. I formatted the entire thing twice, rebooted and started again. Same problem with Gallery. Any ideas other than to throw the hunk of junk in the bin?
I have never (with the exception of the original SPV) had a phone with so many bugs, and that includes a pre-production V66 which used to delete the phonebook everytime you plugged it into the charger!
You're just unlucky with a faulty handset. The 6630, as far as it goes, is a good handset.
Which s/w version do you have? I have v3.45.110
02-12-04
RM-1
Jay3gsm wrote:You're just unlucky with a faulty handset. The 6630, as far as it goes, is a good handset.
02-12-04
RM-1
i can only agree...mine is 3 months "old" and its working properly and iam very satisfied /best device i ever bought/ 😃 only the missing 3G in my country is sad 🙄
