Earn money by developing symbian app
5 replies · 43 views · Started 15 March 2005
Follwoing is specification of some projects. We can change specification with dicussion
Project 1 =Hidden Call recorder
1- hidden "call recorder" ( will not show icon of call recorder in main menu).
2- We can be able to access it by using file manager by clicking
"e:\system\apps\CallRecorder.app"
3- we can store recording files in any directory for example E:\abc\xyz...
4- there will be no time and size limit. (will depend on the size of mmc)
5- there will be no way to find out call recorder application or
recorded files.
Project 2 = Auto start blue tooth.
1- Application will start bluetooth device ( will on bluetooth) when
ever restart the device with out the notice of user.
2- This will be same like autoexec("autoexec" do not start bluetooth
but only open bluetooth menu)and it will also be hidden.
Project 3= Lock menu folder
1- Appliction which can lock the menu folder. So we can lock icon of
call recoder and also other.
All for symbian series 60 mobiles.
Note: In case if you can't develope above project 1,2 then project 3
will work for me.Please, send me Time and cost for these projects at soft.info@ gmail.com .If you can't do this
then please forward me to anyother.
I'm going to shunt this into the admin to see what you all tink. It's all mighty suspicious (add those to cabir for example) so rather than delete can you all let me know what you think on this?
Yes, I agree...very dodgy indeed, I can see a virus use for all those applications, for example if recordings are taken of phone conversations without you even knowing (The point of this?)...bluetooth is always on etc.....very dodgy.
