Colored OpLogo for 7650
90 replies · 16,819 views · Started 08 November 2002
Hello everyone!
I found out that almost here in the forum uses colored OpLogo and i hope you'll contribute some of your colored OpLogo here.
hi, could someone tell me how i can put these colour logos on my phone? (7650)
thanks
[quote="MaleBuffy"]Use SeleQ (trial works as well) browse to an image and select Set as Operator Logo![/quote]
i gotta hand it to you muffy, you're always 1 step ahead in helping newbie questions like that! cheers, brah!!!
yes yes yes....
The size should be 97 x 25 pixels...
Is anybody here have the editor of the operative logo??
Benn 😉
There are quite some posts about this! Try to search for it on the forum! J2theIZZO posted a quick guide taken from the FAQ!
The program that I use to make Op logo is ACDSee V4.0.
This program has a function Acquire ---> Screen ----> at this point, you can set what ever pixel size you wanted (for Op logo set to 97 x 25). Then it will come out as a rectangular box. You place this box to the portion of the picture that you want to make op logo. That's all. You can also make background by this program as well.
*SIGH* My website is proving to be more work than I expected. :cry: It's the formatting of the pics and ringtones that's consuming most of my time, but it'll be well worth it. Patience is a virtual.
Here are some of my Oplogos you can expect to find on my site.
