Some Help Please !!!!!! 6680
5 replies · 1,816 views · Started 01 August 2005
helllo
to start sorry for my english it could be bad because i'm french guy
just i want to know if someone here knows nothing about unlocking the applications you install.
Because i can send this application by bluetooth and when i tried, my phone say's to me errors this application is protected i want to know how to pass trhouth this errors
or if someone have an application that permit to tranfert alll you have in your phone by bluetooth it can say to me
thanks for all 😉
Just go to 'Tools | Manager | Options | Settings' and turn 'Software installation' "On". (While you're in this dialog, make sure 'Online certif. check' is 'Off'.) You can now install any compatible program without being blocked by spurious security warnings!
Steve Litchfield
slitchfield wrote:Just go to 'Tools | Manager | Options | Settings' and turn 'Software installation' "On". (While you're in this dialog, make sure 'Online certif. check' is 'Off'.) You can now install any compatible program without being blocked by spurious security warnings!
Steve Litchfield
thacnks for the response but it's not about that
it's about finding a way to bypass the forwading lock of any application you have installed by bluetooth :icon14:
If you want forwarding files like Mp3 or SIS file, you need a file explorer like FEXPLORER to rename the file ex: xxxxx.sis in xxxxx.si and the OS will allow you to transfert this file via bluetooth to another phone, of course you need a file explorer on the target phone to rename the file back.
I hope this help.
thanks for all men your help is greatfull
it's that i'm seaching for the .Sis it's ok but for the .JAR there is someone for this an application
